-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Engine temperature problems in 928S4 (http://forums.pelicanparts.com/porsche-928-technical-forum/431649-engine-temperature-problems-928s4.html)
ferrispa 09-22-2008 02:02 AM
This is my introduction. Can anyone help me?
I have a porsche 928 S4 Club Sport 1988 5 gears manual. The car is experiencing the following problem. When it is cold, and I start the engine, the temperature rises until approx. 2 to 3 mm. from the red mark. Then one of the fans starts running and also the flaps open,and so, the temperature reduce quickly. then the flaps close and the fan stops. The temperature starts to rise again but this time neither the fan nor the flaps open and the temperature goes to red. I have done all the measurements that the manual suggest to check and everything is between the limits. (The only thing I'm not sure is the values of the resistence according the coolant temperature, because I don't have an accurate thermometer). Any Ideas? Thanks.:confused:
Danglerb 09-22-2008 10:11 AM
Are you sure you have a Club Sport?
Last four digits of the VIN would be I think in the range 5061 to 5070.
I would check the fan electrical system, make sure all the connections are clean and in good shape, test that both fans operate correctly, and swap the fan controller with a known good unit. Maybe starting with a check of all the temperature sensors (somebody will post the details on that).
ferrispa 09-22-2008 01:38 PM
Sorry, but I am spanish- What does VIN stand for?
The engine number is M28.41 81J0178 SP, and according to the workshop manuals it is a Club Sport.
I've checked the fans connecting them directly to the battery. OK.
I've also checked the four sensors and their values are fine.
Do you mean a new control unit (the one that is next to the passenger seat)?.
I have changed the belt for the AC compressor and also the belt was a special length, because the compressor is a bit smaller than the regular one.
On the other hand, I haven't filled the circuit with AC gas yet.
Could it be the reason for my problem?
Thanks.:confused:
Danglerb 09-22-2008 07:11 PM
VIN is the vehicle identification number, stamped in the top of the right fender, on US cars its also on a sticker in the door jam.
M28/41 is correct for all 87/89 5 spd motors, not sure about the rest.
Control unit is up by the bumper on the other side of the hood latch from the ignition module. Its item 10 in this parts diagram.
http://dcauto.gotdns.com/illustration/index/463715658
http://forums.pelicanparts.com/uploa...1222135620.jpg
Be sure to check and clean all the wires and connectors related to the fans and fan control module.
Don't run the compressor without first pulling a strong vacuum for at least 30 min to remove moisture, replacing the receiver dryer, and refilling with oil and freon. If you put on a belt, disconnect the electrical line to the clutch. It should have no effect.
ROG100 09-23-2008 06:27 PM
On top of everything that Danglerb has suggested. If only one fan is running I am going to guess its the controller on the front as already stated.
If both fans run when powered by a direct supply then a new controller is in order.
Double check the fuses and make sure both or one is not melted in any way. A common problem on the later cars.
Congrats on having one of the most special 928's
Roger@************
gattaca 09-23-2008 11:00 PM
Wowoweewee a Club Sport! Very nice! :)
jthwan22 09-24-2008 11:40 AM
You could unplug the flap at the open position. You can't go that fast in US to make a difference any way.
Xlot 09-24-2008 03:49 PM
I had a problem with only one cooling fan running on my '89 S4 when I got it.
It turned out to be the cooling flaps relay - relay XVIII on your '88's electric panel.
In my case, pulling the relay out, cleaning the contacts and putting it back in fixed the behaviour.
Hilton.
PS nice 928! :)
Roger@************
Danglerb 09-24-2008 08:41 PM
Guys help me out on this, I don't know engine ID that well, does his ID show its a Club sport?
928cs 09-25-2008 01:07 AM
Hello,
Could you please indicate your car chassis number (VIN: Vehicle Identification Number)?
If your car is a LHD, then it can only be a 1988 Club-Sport and the chassis number must be wp0zzz92zJs845061 to 5070.
If it's a RHD, it is an SE (UK version, a little heavier and more "common" with 42 produced).
I own the second of the seven 1989 Club-Sport made and try to register these cars.
Where are you located in Spain?
I have friends there that may help you.
Thanks in advance,
Samuel
928cs 09-25-2008 02:58 AM
The SP at the end indicates this is either a CS or an SE.
The M28/41 "SP" is a forunner of the M28/47 used into GT.
No 1988 CS was delivered in Spain so I assume the car is from Germany.
There was one delivered in Autria (still in this country) and another in France (still there too). The remaining cars were delivered in Germany.
From the VIN, I can tell what color the car is and its options.
Samuel
SeanR 09-25-2008 05:30 AM
Check your fuses. If one fan is running it could be that one of them keeps blowing. If that is the case you need to run an out board fuse holder off the central electric panel for better cooling.
ferrispa 09-25-2008 01:51 PM
Thanks everyone for all your suggestions. I am working my way through them!
The VIN is WPOZZZ92ZJS841828 and the car is RHD as I bought it in the UK last year.
At the start I didn't know the model of the car but, after reading the workshop manual in section 15-139 I saw the first reference to the suffix "SP" so I assumed it was a Club Sport as that section says. On the other hand , I don't know what "SE" means.
I live in Bilbao in Northern Spain and any local contacts are very welcome.
EuroShark 09-25-2008 02:47 PM
Not sure if these have the viscous clutch type fans of the early 928s but i had an overheating problem on mine, and it turned out the clutches inside the fan were shot. I actually welded the fan for a temp fix and it kept the temp down;)
928cs 09-26-2008 07:38 AM
An SE is a UK specific version of the Club-Sport. In fact, it is a limited edition with all cars identical, except the color. It was available in black, silver, red or white.
If I'm correct, your car is white and was registered EDZ6677. This is the only one delivered in Ireland.
I think your engine number is not accurate. A figure is certainly missing.
I have the original SE press kit if you would like to read it.
Samuel
ferrispa 09-26-2008 12:45 PM
You are spot on! My car is white with the number plate you quoted. Amazing!
M28.41 81J01078 SP--I made a mistake when I copied the engine number. This is the correct one. I would be very interested to read the SE press kit if possible. My e-mail is ferrrispa@hotmail.com.
Many thanks
ferrispa 01-01-2009 02:42 PM
After checking all sensors and trying all those suggestion given, I finally changed the control unit 928 618 418 00 and PROBLEM SOLVED!!!!
Thank you everyone for your help
Xlot 01-02-2009 12:59 AM
Glad its fixed!
I see from the earlier posts that your car is a right-hand drive 928 SE.. very nice - a friend here in Australia has one!
