Engine Swap Possibilities
I may be purchasing an 82 928 w/ 5-speed tomorrow. Car has sat for 3 years but was a fully functional car before it was parked. Had all new sycnros and clutch prior to being parked.
What later, higher horsepower, motors easily (relatively) will fit into this car? I'm not expecting the relative ease of putting an 84-89 911 motor into a 69-73, but what are my options for this car? EDIT: sorry, saw a post like this down below. please ignore.
Tru6 Restoration & Design Last edited by Shaun 84 Targa; 12-15-2008 at 03:46 PM.. |
Heavy Metal Relocator
not to promote an "ignorance", but you didn't specify a US spec 82 or a Euro (ROW) spec.....there is a big difference, when discussing engine swaps or upgrades. --Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
Russ, for the price, it can only be U.S.
from the post below, it looks like a euro motor will be the best option down the road. I've driven 84 autos and thought they were dog slow. Can't imagine an 82 5 speed will be that much better, though the after I go through the car, the interior will be gutted and anything heavy will be removed, so that will help a little.
Tru6 Restoration & Design |
actually, you will find Euro's and US spec cars priced pretty close---not much difference between the two.....
the Euro cars will be about 150 pounds lighter. big difference is the 4.7L Euro "S" @ 300 hp. if this is something you're planning on gutting, expect to pay no more than a few hundred, certainly no more than a thousand bucks---- --Russ
it's one of those cars that everyone tells you not to buy. if Euro, will it have ZZZ in the VIN?
yes, few hundred $. I imagine after doing a compression test, first thing I would do is timing belt and water pump?
Network Native
Swapping in a Euro or Euro hybrid motor is the way for HP, but gutted out no AC etc. removes nearly 400 lbs or so, put some 85/86 US exhaust manifolds and an X or Y pipe and you might not find the 82 so tame.
A 5 spd is NOTHING like driving an AT. Trust nothing a PO tells you that you can't test, and not running for a few years is typically a LOT more than the PO remembers. OTOH best of luck and be sure to post picts.
Network Native
Actually FIRST thing to do is drain the fuel tank and flush the lines. I would then squirt some oil in each spark plug hole and let it set over night, then do a compression test. With a dry, cold motor compression test won't mean much anyway. 82 non Euro isn't interference, no harm done if the belt breaks, so no point in diving in that far until you know you want to keep the motor, and/or car. Get it started and let it come fully up to temp a couple times, then change all the fluids and filters.
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
be very careful of this, as the 80-82 Euro's had two different engines (4.5L 229 hp and 4.7L 300hp), if it's a US, then there's only one....4.5L 220 hp, all of which are non-interference engines, so don't sweat the TB/H2o deal. get it started and drive it until the belt breaks, unless you don't want to take the risk. (we did this with my Dad's 79, only because we had no history on it--yeah, we were being lazy------). --Russ
Thanks Russ, the car was actually a no-go. What were described as minor dents that could easily be pulled out in the passenger rear quarter, in fact went into the B-pillar.
I'm putting an entire rear driver quarter on my 72 Targa, a relatively easy proposition. I can't even imagine doing it on a 928. The search continues. thank you for your help!
