new dyno numbers---it's not what you think
latest dyno numbers, at the rear wheels.....
engine rated speed--2000 rpms coolant temp--133 degrees oil temp--209.75 degrees intake temp--67 degrees engine oil pressure--36.5 PSI engine load--99.5 % percentage wheel slip--6.94% 533.18 horsepower 569.55 corrected horsepower (actual measured horsepower plus slip % correction) :D --Russ |
so what vehicle was this done on?
I think his front bumper and one tire weigh more than a 928.
I did it yesterday with my #1 Peterbilt......thought it might be fun to list the numbers here ('cause everybody else does with their rides....er, cars).....:D
I had an ECM failure and figured I'd have them dyno it after the new ECM, and for a engine that's got 885,000 miles on it, it came out pretty good..... the engine is only rated for 600 hp, and you can usually figure a 20% loss at the rear wheels, so 569 was way above what I expected. One of these days, I'll have my Euro motor put together and then have some fun with the numbers----:D --Russ |
| All times are GMT -8. The time now is 07:19 AM. |
