Heavy Metal Relocator
rhjames's Avatar
new dyno numbers---it's not what you think
latest dyno numbers, at the rear wheels.....
engine rated speed--2000 rpms
coolant temp--133 degrees
oil temp--209.75 degrees
intake temp--67 degrees
engine oil pressure--36.5 PSI
engine load--99.5 %
percentage wheel slip--6.94%
533.18 horsepower
569.55 corrected horsepower (actual measured horsepower plus slip % correction)
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 12-16-2008, 08:30 PM
lizard928s's Avatar
so what vehicle was this done on?
Old 12-16-2008, 09:45 PM
Network Native
Danglerb's Avatar
I think his front bumper and one tire weigh more than a 928.
Old 12-16-2008, 10:34 PM
rhjames's Avatar
I did it yesterday with my #1 Peterbilt......thought it might be fun to list the numbers here ('cause everybody else does with their rides....er, cars).....
I had an ECM failure and figured I'd have them dyno it after the new ECM, and for a engine that's got 885,000 miles on it, it came out pretty good.....
the engine is only rated for 600 hp, and you can usually figure a 20% loss at the rear wheels, so 569 was way above what I expected.
One of these days, I'll have my Euro motor put together and then have some fun with the numbers----
--Russ
Old 12-17-2008, 05:08 PM
