Gas Cap
I just picked up an 82 928. It has no gas cap. I assumed that a "cap is a cap", but have now found that Stant doesn't make replacements. Any easy way (cheap) to get a replacement?
Old 11-30-2008, 07:07 AM
Network Native
Danglerb's Avatar
The 928 gas cap is unique, nothing else uses one, so new from Porsche or used and take your chances on it sealing or locking. New cap comes with a new key and lock, but you can get the locks rekeyed to match your car if you want.
*** Porsche
Pelican and most of the usual suppliers have new gas caps, but they are from Porsche.
928-201-903-02-M100 Gas Tank Cap, 928 (1978-95)
Brand: Genuine Porsche $157.00
Old 11-30-2008, 07:55 AM
Thumbs up Gas cap info
Thanks for the answer. I think I'll investigate to see if I can swap out the whole filler neck, that would use a standard cap. I'm not really trying to restore to factory original, just drivable for some fun.
Old 11-30-2008, 12:18 PM
Network Native
Danglerb's Avatar
Filler neck is part of the tank.
If the previous owner didn't bother replacing the gas cap, my guess is that you have a VERY expensive project ahead of you, and few corners to cut costs on. Before you start spending any money on it a complete inspection and guesstimate of repairs might be a good idea.
Old 11-30-2008, 12:39 PM
928 OB-Wan
Rixter's Avatar
I'm sure I have 1 laying around, may not have the key though
figure $50 + shp w/out key $75 w/key
78 928 Euro 5spd #34
88 928 S4 AT NachtGrun/GrauGrun
88 928 S4 5spd Guards Red/Black
12 Volvo C30 IceWhite/Black
Old 12-01-2008, 04:34 AM
MPDano's Avatar
Does this 82 run? If not, I think Dangler is right, your in for a treat. All kinds of crud can be at the bottom of your tank. Anyways, Rixters got a cap, buy his and seal up that tank. Your most likely going to have to pull the tank and have it cleaned.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-01-2008, 04:47 AM
Old 928 Guy
surfdog4's Avatar
..just be sure if you get a used cap that it includes the o-ring seal. some places sell them separately
1990 C2 Cabriolet Guards Red
'81 928 Zinnmetallic Project Car (sold) )
'87 944na Maraschino Red Metallic (sold) )
Old 12-03-2008, 06:29 PM
Been gone for awhile. Hope you all had a good Christmas. Yes, the car runs (needs tuneup maintenance). Filler tube is rigid to the tank? That adds a minor problem. But, I wouldn't care about cutting it off, and then adding a fuel filler from something else, with a piece of flexible hose. Ever seen a parts blow-up / exploded view? Bought a CD with the maintenance / repair (it's the shop manual). But, it is lacking in pictures / diagrams. For motorcycles, bikebandit.com has exploded diagrams for everything. How about a 928?
Old 12-28-2008, 04:49 PM
Heavy Metal Relocator
rhjames's Avatar
As danglerb says, the filler neck is part of the tank. you can cut the top off and fashion some sort of non-Porsche 928 deal, but I wouldn't.
Used gas caps with keys are available (the major 928 parts suppliers, eBay, etc).
PET manual/CD has the exploded view of the entire car/parts.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 12-28-2008, 05:14 PM
rhjames's Avatar
below is the exploded view of the fuel tank and related parts. the view is a little misleading, but if you look closely to the filer neck, you can see that it is part of the tank.
--Russ
Old 12-28-2008, 05:20 PM
Network Native
Danglerb's Avatar
I haven't seen a 928 yet that needed what might be called a tuneup. Rough running is usually some combination of vacuum, wiring, failed sensors or some actuator. No gas cap would have me point the first finger at contaminated gas, water, dirt etc.
Fuel tank is a big $1k plastic thing that hangs from a metal bracket in or near the portion with the filler neck.
Old 12-28-2008, 05:38 PM
928: Serial Enabler
Ditto on the tuneup. As Danglerb says.
On the gas tank --- carving on that gas tank to avoid spending money on a missing gas cap? Buy the cap. Clean the tank. Your fuel pump is $250 to replace and it will likely fail in several months because the strainer built into the discharge fitting is too coarse to prevent debris from entering the pump and, like russian roullette, jamming it.
In general ----
Part of the reason Porsche could accomplish the performance on these cars is singular engineering of every part, with few exceptions, and morphing of the parts year to year as needed to accomplish other enhancements.
Starting to carve on them is a slippery slope. You can rig stuff and it might work, but the degradation of the car will be irreversible.
These are not chevelles.
84,85,86 928 cars
Old 12-28-2008, 07:57 PM
rhjames's Avatar
Yep......what they said...!
--Russ
Old 12-28-2008, 08:09 PM
MPDano's Avatar
Like I said, pull it out and have it cleaned. You will regret it later if you don't. I think I paid $60 to have mine acid washed.
Old 12-29-2008, 03:48 AM
