-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   My compression test. (http://forums.pelicanparts.com/porsche-928-technical-forum/448139-my-compression-test.html)
mrtiffin 12-26-2008 02:03 PM
T1 T2
Cyl. 1--130-140
Cyl. 2--150-150
Cyl. 3--120-120
Cyl. 4--175-180
Cyl. 5--170-175
Cyl. 6--150-155
Cyl. 7--170-175
Cyl. 8--175-175
Ran two tests, 1st test regular, 2nd test with a few drops of oil.
N2O-SHARK 12-26-2008 03:59 PM
Looks like some leakdown issues. All should be within 10% of the median amount. #1 and 3 are too low. Are you sure you had both valves closed with each test?
mrtiffin 12-26-2008 05:53 PM
I followed rhjames's directions to the T. At least I think this was the concept.
Unplug all spark plug wires, pull all spark plugs, screw compression device into first hole, then cycle the engine 8-9 rotations. I went from #8 to #1 then with the oil test #1 to #8.
mrtiffin 12-26-2008 08:26 PM
Russ, call me real quick.
rhjames 12-26-2008 08:29 PM
it's my standard "old skol" compression test.
not a leakdown test. for that, you need a compressor and fittings and blah, blah........or one of those fancy leakdown testers.....;)
anyway, as I suggested, you can try the chemical remedies for the bad cylinders, or do what I just did and tear it out and strip it.
you really have 4 that aren't getting it done--1, 2, 3, and 6.
could be stuck rings as we discussed, or worse.
We'll discuss that tomorrow when I get down to your place......:D
--Russ
