Question if I could only figure this out...
Drove my car into my drive way, shut it off and it wouldn't start again. Not one spark! Replaced the ignition control module, spark plug wires, cap & rotor button, courtesy of 928 International but still the baby won't start. WTF!! I have spark and fuel to the engine. Any sugesstions...
Old 01-10-2009, 04:04 PM
Network Native
Danglerb's Avatar
US or Row? Model year?
Doesn't crank, or cranks but doesn't start?
Is the fuel pump running while you try to start?
Check for spark with a timing light or by pulling a plug and watching.
Check for fuel with a noid light at a injector if the fuel pump runs.
Old 01-10-2009, 04:48 PM
Dean_Fuller's Avatar
what year is your car? Anything odd before the no start?
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
no start
have you tried a little starting fluid? (just a little)
did you check the cam and ign timing? double checked the firing pattern?
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 01-10-2009, 04:57 PM
Do you have an alarm system that shuts off the ignition. My 83 does.
Current: 914/6 GT Conversion, Cayman
Old: Many PCars + Formula Racecars
Old 01-10-2009, 07:46 PM
'83 928 US model... No alarm and nothing odd before parking it. I have both fuel & spark as well as I hear the fuel pump kicking on. Car has gas... tried starter fluid but nothing. The car wants to crank and runs for breif second but it's very rough. I had the firing and arranged everything they way it should go. To me it sounds like timing but I don't see how! If you know the firing order let me know and I'll look around for the one I had to see if it matches... Thanks
Old 01-11-2009, 07:39 AM
sorry it's an '81 928... firing order I have is 1,3,7,2,6,5,4,8. What's the numbering of the cylinders on the left and right bank?
Old 01-11-2009, 08:52 AM
Heavy Metal Relocator
rhjames's Avatar
cylinders are numbered as follows:
Passenger side front to back 1,2,3,4
drivers side front to back 5,6,7,8
if you have spark, fuel at the injectors (they should click or buzz), and compression (timing belt OK???), it should run---basic engine 101 stuff.
However, if the timing belt has either broken to jump teeth, it ain't going anywhere.
check compression in cylinders to confirm.
timing belts are subject to breakage at any time, even when you pull it in the garage, shut it down, and then try to restart.
I would check the TB first before moving on to spark or fuel computers and such.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 01-11-2009, 01:12 PM
Network Native
Danglerb's Avatar
Spark, fuel, compression, just like Russ says.
I'm lazy, so I tend to check easy stuff first.
Timing light for spark and spark timing.
Noid light to check for injector signal.
Then pull the plugs and check compression.
Pull the plugs immediately after a starting attempt, and check for wet fuel on them, as well as color etc. If they aren't wet you aren't getting fuel.
Old 01-11-2009, 01:23 PM
cylinders numbered: passenger 1234; driver 5678... I brought #1 cylinder to TDC, rotor button isn't exactly pointing on #1 but it's close. on the distributor cap iv'e started with #1 with firing order 1,3,7,2,6,5,4,8 going clockwise. Have fuel & spark... now I it doesn't crank and I can hear it lobing in the exhaust... I'm not able to make out what marking on the cam gear I'm suppose to be lining up with the mark on the casting, which I can't make out either. The manual gives no close up... what next on this??? I now there was a post about 3 months ago where everyone went into to great detail on timing w/pics and all. If someone could send the link on that post I might be able to solve my problem.
Old 01-11-2009, 02:45 PM
Network Native
Danglerb's Avatar
Cranking means the motor is being turned by the starter.
How did you test for fuel and spark?
Easier to test for compression than to check cam timing via marks. (easier for me to explain how anyway). One of the victims of the last cam timing adventure is sure to post a link, but I'm not sure how educational the thread is ...
Do you have a full charge on the battery and clean contacts? What voltage do you get at the jump post?
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 01-11-2009, 02:56 PM
A Wrench
SeanR's Avatar
Suppose we should start with basics here.
Pull a plug wire on each bank of cylinders, arc them to ground with a screw driver. Have someone crank it over. Do both sides show an arc of spark? If so you have spark.
If you jumper the fuel pump relay 30/87, do you hear the fuel pump running? If so, you have the means for fuel pressure.
If you have a no start issue from here on, then you have a fuel delivery problem to the injectors.
Now on the horrible side, you might have all of that going on but your cams are not turning. Check to see if your cams are turning through the inspection holes on the intake breathers. These are located under the intake tubes. Take a flash light and look in as its cranking.
'88 Supercharged and lots of other fun stuff.
Old 01-11-2009, 05:08 PM
Gas
If you pumped the gas ,very easy to foul them out
Old 01-11-2009, 05:11 PM
SolReaver's Avatar
either bunny
Does it kick on a puff of starting fluid? that is another way to check for no fuel. don't use too much though, it can wash down piston walls.
Old 01-12-2009, 11:54 AM
