Send a message via Skype™ to mtnclimber47
Electrical issue
I have a '90 s4...
About a month ago the onboard computer flagged a headlight that wasn't working... which was odd because the bulbs were only a month old. Nevertheless, I changed out both bulbs. The problem persisted, and after some checking, I realized that the right headlight (source of the problem) actually worked... but sometimes had a delay before fully illuminating, and other times would be only partially on.
I don't know a lot about electrical systems, but it seems that either a relay is off, or there is a short somewhere. I examined the headlight mechanism, and it seems to be fully in tact, with no loose wires in sight.
Any suggestions?
Mike
Old 02-10-2009, 11:49 AM
You might try swapping the headlight relays. I think #'s XXIII and XXIV in yours and see if the problem swaps headlights.
Butch
_______________
78 (Grover) May run someday.
Old 02-11-2009, 11:46 AM
Automotive Necromancer
SolReaver's Avatar
Send a message via Skype™ to SolReaver
well grounded
Clean and check all the connections and grounding points.
X2 on the relay swap.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix.
Old 02-11-2009, 01:23 PM
