Reverse lights on...
Hello Guys,
I have a 1987 928 S4. My reverse lights remain on even when I'm in D. The car has an auto trans. Any ideas out there? Thanks. Sprint. |
Check the back up light switch to make sure it is not stuck. If it checks out fine, check the relay in the panel and see if is is stuck. I mostly find the switch to be at fault, but have had a relay or two, and a ground wire cause this same issue.
Hope this helps Kris Enniss The European & Import Professionals Mason, MI 517-676-1395 |
See i have a problem with the reverse lights but its totally opposite, my lights never come on. I subscribed to a 928 international magazine a while back....i called them and they were great help fixing mine...if you still have problems cal them, 714-632-9288....they were a big help!
Mine does a similar thing. But in drive D it manages to stay off. Then if I cycle the trans from R to P it will shut off in P. Otherwise it will remain on.
I did find a faulty relay... because they were never on at first. I replaced it and bingo I thought they are on... Whoops... they are on almost all the time now. I think I will go back into the relay board and make sure the ground is properly connecting. Any idea where the back up switch is? Or is it part of a PRND2 switch under the shifter area?
82 924 restored, 83 944 parting out In search of 1988 or newer nice 944. |
Network Native
