-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   MPDano's 928 going to Smog this Week (http://forums.pelicanparts.com/porsche-928-technical-forum/463323-mpdanos-928-going-smog-week.html)
MPDano 03-16-2009 06:49 PM
Ok, a little update for you (3.16.2009). I just spoke to my mechanic after they installed the good used AAV. They did their adjustments and got it to:
CO: .50
HC: 100
According to him, this is acceptable levels but he is not smog certified and has no way to check NOx with his tester.
The bad news:
Recently before I brought it to them, maybe around a month ago. I would start the car cold and I would get a lot of white smoke. In my used car experience, that would be coolant. It did disappear once it got warmed up though. Hence, why I did the oil change just before bringing it to the Mechanic. Well, he diagnosed it as a bad head gasket but he also said it is a very little leak since it goes away quickly. He said that I could try some of that leak sealer of some sort to try and fix that without removing the heads. Of which I highly don't want to remove heads. I seriously don't want to remove that engine. Anyways, he did state that this wouldn't cause me to not pass smog. Ok, I feel better now. Anyways, anyone got any suggestions on which sealer works of which you have experience with?
Danglerb 03-16-2009 07:11 PM
No clue on the coolant glue.
Smog it, drive it, and have some fun. ;)
tedward515 03-16-2009 07:50 PM
Look on the bright side, with all of the white smoke your neighborhood should be mosquito free:D
I knew a mechanic who talked about using something that would seal up real small coolant leaks, but of course I can't remember.
On a more serious note good luck with the smog test. I can't even imagine how frustrating those things must be.
devilinblack 03-16-2009 07:55 PM
Mine was smoking from under the hood when I got it smogged. The rear cam seals leaked and burned on the exhaust. Smog guy pointed at it and gave me a look, I just shrugged and he went on with the test.
MPDano 03-16-2009 08:06 PM
Did it pass?
devilinblack 03-16-2009 08:30 PM
Yup, sniffer test was fine. Guess smoke under the hood doesn't count. I wouldn't think that water in the exhaust would either, just make sure the car is completely warmed up before going and don't shut it off!
rhjames 03-16-2009 08:39 PM
let us know how it checks out.....
--Russ
MPDano 03-16-2009 08:42 PM
HI Russ,
Oh yeah, you guys will be the first to know. Good or Bad.
MPDano 03-28-2009 09:52 AM
Ok, time to update this thread. Brought my car to get Pre-Smog Inspected this morning. Drove the heck out of it prior. Here are my results:
15mph
HC=128max measured 128 PASS
CO=.93max measured .05 PASS
NO=1097max measured 136 PASS
25mph
HC=101max measured 87 PASS
CO=.73max measured .07 PASS
NO=927max measured 133 PASS
All PASS Tailpipe, should be good to go, right?
Results=FAIL
Why? 1981 US Model has EFI NOT CSI, no O2 Sensor found. My car is a 1981 EUROPEAN
The Inspector has to go by the year posted on the label which is a US 1981. A Euro 1981 928 is CIS with NO O2 Sensor. I need to go to a Referee Station and explain to them that it has the same FI System as a 1979 and I need a BAR Label to Inspect to a 1979 Standard. Although this is f%^%$# up, I do know that my tailpipe emissions was right on the money. Why can't I get a blind smog tech? BAR Referees closed on weekends, will call on Monday. Man, this is nerve racking!
Xlot 03-28-2009 10:15 AM
One of the guys on that other site who has 4 928's (all 89/90) has a RoW car that had no O2 sensor from factory
When it was federalised, the O2 sensor was added to the exhaust pipe, but wasn't actually doing anything as the federalisation shop didn't know to change coding plugs etc.
Can't you just add a cheap old dead O2 sensor and plumb some wires into an unused fuse holder in the back of the CEL? :)
MPDano 03-28-2009 10:18 AM
I could but they saw it was also CIS. Can't fake that.
Danglerb 03-28-2009 12:45 PM
Leo, you don't have a BAR sticker?
Hate to say it, but you may be in for a bumpy ride. Was it registered previously in Calif?
The referee station will require full compliance, not just a tail pipe, but end to end full compliance which means 100% of a Calif EPA certified emssions system needs to be present.
Did the smog guy actually run a test and the test directed you to a referee station, or did he look at it and say you need to go to one, ie have you been tagged in the system?
devilinblack 03-28-2009 01:56 PM
Yeah, if you're not in the system I'd plumb in an O2 sensor and make the wire disappear in the harness and find a dumber shop. The place I went to didn't even know that it wasn't a 911 so there's no way in hell he'd know CIS from EFI from a freaking coffee can.
But yeah, having to go to a referee is not a good starting point. Good luck with it and keep us posted.
Dean_Fuller 03-28-2009 05:16 PM
"referee station"!!! Gees....What next?
MPDano 03-28-2009 05:39 PM
NO, this was just a pre-test and he recommended me to go to a Referee Station to get a new Bar Decal to state 1979, so it will be tested under 1979 specs. Ie, nothing was sent to the DMV. Do you think this will be an issue?
MPDano 03-28-2009 09:30 PM
This is what is on my drivers side door jamb. Yes, this is a California Registered Vehicle. Last Pass was 1998, hence the 2000 year decals on the Blue California Plates.
Danglerb 03-28-2009 10:19 PM
Sticker will look something like ...
http://forums.pelicanparts.com/uploa...1238303863.jpg
Danglerb 03-28-2009 10:21 PM
My advice, proceed slowly, and make no irreversible steps.
Check the smog history and maybe give it a try at the last place that passed it.
Danglerb 03-28-2009 10:29 PM
I'm not sure what it means, but that test is already in the system, and last passed was some Tuneup Masters in 98.
LAKESIDE RADIATOR /
LAKESIDE PORSC 928 1981 03/28/2009 08:12 a.m. T
ONE STOP AUTO TECH /
SANTEE PORSC 928 1981 07/11/2003 09:37 a.m. F
SANTEE PORSC 928 1981 06/12/2002 09:46 a.m. F
ADVANCED AUTOMOTIVE /
SANTEE PORSC 928 1981 06/12/2002 08:34 a.m. A
TUNEUP MASTERS #411 /
SAN DIEGO PORSC 928 1981 01/15/1998 10:26 a.m. P
Danglerb 03-28-2009 10:32 PM
Also looks like the Cal DMV registered it as a grey market vehicle on
06/03/1986 CA Motor Vehicle Dept. GREY MARKET
MPDano 03-29-2009 07:28 AM
Yup, Grey Market is correct. I am thinking that 1986 is probably when it was imported and federalized. Title also states "Non US" on it.
What does this all mean in the BAR Referee scheme of things?
Danglerb 03-29-2009 08:13 AM
Hopefully it means the DMV already knows you, and accepted your car as a "federalized" ok to register in Calif vehicle, just without a BAR sticker due to time parked out of the system.
This is the first case I know about for a Euro that was registered, but doesn't have a BAR sticker.
Next thing I would do ....
Put in a bung and O2 sensor and run the wiring up into the harness.
Sort out the HC, its too close to failing, maybe due to old cats so kill two birds with one stone and put on a nice late model cat and a o2 sensor.
Try again at another normal smog test station and see what happens. Be convincing that CIS is the normal factory motor your car is supposed to have.
MPDano 03-29-2009 08:59 AM
What about this cat? Calif approved OBD2
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=390034885087&fromMakeT rack=true&ssPageName=VIP:watchlink:top:us
...and this Sensor
http://cgi.ebay.com/ebaymotors/PORSCHE-O2-Oxygen-Sensor-911-924-928-944-930-944-78-95_W0QQcmdZViewItemQQ_trksidZp3286Q2em20Q2el1116QQ hashZitem380112339614QQitemZ380112339614QQptZMotor sQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Danglerb 03-29-2009 10:23 AM
This one I am pretty sure is what the CALIF smog entry in the Magnaflow catalog lists for the 928.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=360113658610
But when my car was smogged they just looked for a cat and counted how many.
Its not getting hooked up to anything, why not this one?
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=170314743212
MPDano 03-29-2009 11:09 AM
Ignore
MPDano 03-29-2009 01:19 PM
Mike,
This is what comes up for OBDII Compliant specifically for California on Magnaflows website
http://www.car-sound.com/02product/displayuniversal01.asp?catalogid=47560&universal=3 6037
Danglerb 03-29-2009 02:07 PM
Ah, my link is for the 49 state OBDII compatible cat. I think its a better cat, but the referee station might be checking the actual model numbers. They sure look the same, hard call, maybe it would depend on if you have to go to the ref or not.
orange9mm 03-29-2009 02:39 PM
that eBay magnaflow cat looks good. if we had emissions here that is what i would go with.
MPDano 03-29-2009 07:25 PM
Mike,
Post your Euro BAR Decal.
Danglerb 03-29-2009 10:34 PM
Originally Posted by MPDano (Post 4575593)
Mike,
Which one of my EURO BAR decals? ;)
Maybe Tuesday, too much junk in the way on the one at home, not visiting the black one til Tuesday.
MPDano 03-30-2009 11:16 AM
Ok, made an offer on the correct cat for calif and 928 and got it.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&it em=280324699167
How about this O2 sensor (3wire for heater), will year matter? This will be hooked up to an A/F Gauge.
http://cgi.ebay.com/ebaymotors/O2-OXYGEN-SENSOR-UNVS-3W-SG54-PORSCHE-928-95-93-91-87_W0QQitemZ370146275031QQcmdZViewItemQQptZMotors_ Car_Truck_Parts_Accessories?hash=item370146275031& _trksid=p4506.m20.l1116
MPDano 03-30-2009 12:53 PM
Ok, just got off the phone with the one who did the test on Saturday. That "T" in the code is Tamper. WTF! Anyways, whats done is done. Anytime I got to re-test, he said a red screen comes up with why it failed ie: equipment not there or something, but not a specific part.
Maybe I should just do what Tom Cruise did in the movie Risky Business and roll it into Mission Bay. "Who's the U-Boat Commander?"
Danglerb 03-30-2009 01:57 PM
Cr@p, same thing happened to me with my old Lincoln when the cats went bad. I told the guy who was trying to sell me a $150 injector cleaning to run a pretest and got flagged as a gross polluter. Done is done, assuming this means any place you take it to will have you flagged?
Did you find out why he failed you, lack of O2 sensor, or not Jjet?
If it has to go to a referee station, the good news is that they are both smart and used to working with people to get their cars to pass. The bad news is that they are smart and not very big on bending rules. Two things come to mind;
Find out what the car should have on it, what the requirements were for a federalized 928 of that model year.
Visit or talk to the referee station. They are usually part of a community college auto program, and teach smog inspection as well as doing the testing. The right person might be able to point you in the best direction or explain what equipment the car needs to pass and get a sticker.
Worst case, swap in an Ljet intake and brains.
Best case, maybe the smog guy screwed up and you should have passed?
Likely case, maybe you already have some of the federalizing bits, or they won't be that hard to find and put back on?
Fixing the smog is STILL the previous owners responsibility.
MPDano 03-30-2009 02:09 PM
Yeah, he explained to me that if I were to do a real smog, it would have been tagged a GP (Gross Polluter). The thing that gets me is that I was very specific that i wanted nothing sent to the State. Well, it did. His shop gets a big fat red flag (Lakeside Radiator & Auto Repair) in my book and hopefully other will heed to the warning.
Swap L-Jet you say. Nah, this is when this 928 becomes home for the fishes and scuba diving classes in the Harbor.
Danglerb 03-30-2009 07:24 PM
I suggest sticking with a Bosch universal O2 sensor.
I have to admit it would look cool for scuba class, but I suspect you will need a few permits before you get your U boat commander license.
MPDano 03-30-2009 07:26 PM
Yup, that's the one I got. A Bosch single wire Universal. SmileWavy
devilinblack 03-30-2009 07:46 PM
If you're hooking the O2 up to an Air/Fuel meter, don't you need a wideband?
MPDano 03-30-2009 08:00 PM
According to this vendor, it only needs a signal wire from your stock O2. I emailed them to confirm.
http://prosportgauges.com/blue/White-air-fuel-ratio-gauge.aspx
http://prosportgauges.com/images/pro...AnalogBlue.jpg
Danglerb 03-30-2009 09:51 PM
Two kinds of AF meter, wideband that looks at the voltage and reports, and narrow band that looks at the on and off and show a kind of average depending on mostly on or mostly off. I'm not sure narrow band is all the useful for actual tuning.
OTOH wide band O2 sensors often don't last long when the mix is all over the place, ie tuning. My sensor was about $48 from amazon, but I haven't played with it yet (using a borrowed innovations LC-1 when I do play with it).
MPDano 03-31-2009 07:20 AM
The way I see using the narrow band is that as long as I can use it and see that i am within Optimal or Stoich range, then I should be golden. It should also let me know where within the range is under WOT. I also thought of the wide band, but didn't big LED numbers staring at me. I didn't feel it was really necessary. I am probably wrong though.
