Angry 1987 928s4 stuck in 3rd gear
my 928s4 now seems to be stuck in 3rd gear haven't a clue what could be the cause or the solution. i am new to Porsche after owning a total of 5 Mercedes over the years.never had one problem with any of my mercs but have had a lot of problems with the 928, the main problem being there is only Porsche dealership in northern Ireland and they are not very helpful (unless your wanting to buy a 997) plus real car enthusiasts like the smell of petrol not coffee when they go to look around cars(know what i mean).
so can anyone out there help me out with some advise.
Old 03-31-2009, 12:04 PM
Stuck
Steve,
Your description is not complete, however; if the car is a five speed it is possible the shifter ball socket poped out. The other possibility is the rear shifter coupling.
Old 03-31-2009, 01:08 PM
Network Native
Danglerb's Avatar
And if you have an automatic then its a Mercedes problem.
First thing to check on an auto is fluid level, replacing if old.
Shifter on a 5 spd connects to two rods on the bottom, one going forward with a plastic cup over a round ball (cup pops off ball).
Old 03-31-2009, 10:38 PM
Originally Posted by 928gene928 View Post
Steve,
thanks for the advise. as far as i know my car has a 4 speed automatic gearbox. i can select reverse/neutral and park but only what seems to be 3rd going forward.i changed the gearbox oil and filter and adjusted the bowden cable but am at a loss at what could be the problem.
Old 04-06-2009, 05:49 AM
i replaced the gearbox oil and filter and adjusted the bowden cable. according to my handbook the car has a 4 speed automatic gearbox . i can select reverse/neutral and park but the car seems to be stuck in 3rd gear going forward.
any ideas?
regards steve
Old 04-06-2009, 05:56 AM
MPDano's Avatar
All gears are in 3rd? Just to clarify, when you put in "1" or "2" etc it stays in 3rd?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-06-2009, 07:40 AM
as you say . when i select 1st 2nd or 3rd. it just seems to stay the same as drive.
Old 04-08-2009, 08:13 AM
