If a person wants to do things on a budget and make their life easier, I suggest sticking with your old R12 system as you won't have to buy any service port adapters or other stuff that R134a requires. Just buy 3 old 16 ounce (1 lb) cans of R12 refridgent off ebay, craiglist, or at a swap meet. A lot of times the people who are selling it just want to get rid of it and wll throw in their dispenser for free. Have a friend sit in your car while you fill you a/c system on the low side service port and have him/her let you know when it gets cold. If I remember right, the refridgerant capacity is just over 2 lbs on most 928s (look at the sticker in your engine bay) so the a/c should start to get cool by the end of the 2nd can if your system is really low. If you want to get fancy, rent or borrow a friend's leak detecter and go around your a/c system to see if there are any large leaks so when you your system leaks the refridgerant out you will know which components you need to repair/replace on your a/c system before you fill it up again. |
Automotive Necromancer
Mr. Safety says
Hey guys. Careful about warming freon cans. it increases their pressure and there is a risk of explosion.
There may be nothing quite as expensive as a cheap Porsche: Ruby Red 84 928S : White 87 924s 2.5L NA (Blinky) M44/07-43H10676 spoiler delete - 046/2B - Belts 9/12, Clutch and OC seals 8/08 andd Red 94 Del Sol: Please put your Make, Model and Year in Sig. Try not to break more than you fix. Last edited by SolReaver; 04-22-2009 at 09:53 PM.. |
At a minimum, buy the gauges and find some R-12.
134a is not compatible with the mineral oil used with R-12 and will lead to compressor failure. Maybe not tomorrow, or even next week but is there really a point in doing this half assed and having to do it over again? Some reading to be found here: http://www.allpar.com/eek/ac.html |
Thread Tools | |
Rate This Thread | |
