123 123 is offline
83 Porsche 928S (Euro)
I
Iīve got a 1983 928S Euro Porsche and i want to upgrade the brakes, but donīt know which calipers can i use-only the ones from the S4 or can i use 964 or 993 brakes?
Thank you
Old 04-21-2009, 04:48 PM
Network Native
Danglerb's Avatar
As far as I know you have S brakes and will need to upgrade spindles and A arms to use larger brakes.
Are you having trouble with your brakes?
Old 04-21-2009, 09:42 PM
123 123 is offline
Iīm feeling them a little bit spongy... But the truth is that the previous owner hasnīt change the brake fluid, so i guess itīs been there for quite a while...
Iīll start by changing the brake fluid to Atre Super Blue and then see what happens.
Thanks for the help!
Old 04-22-2009, 10:28 AM
Network Native
Danglerb's Avatar
Fresh fluid and the stock S brake should be fine.
Porsche brakes may also take a bit more force before you reach max braking than you may be used to from other cars.
Old 04-22-2009, 12:24 PM
123quattro's Avatar
Brake fluid should be changed every two years on street cars. Coolant is the same. Most never do either.
Old 04-22-2009, 02:14 PM
MPDano's Avatar
Damn, every 2 years. I totally never did this on any of my many cars I've owned throughout my life. Good to know.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-22-2009, 02:28 PM
123 123 is offline
Me too...
And can you explain me what "Spindles" and "A arms" are so i can get the correct term in Portuguese.
Old 04-22-2009, 04:34 PM
devilinblack's Avatar
Spindle (the thing on the right):
A Arm (upper):
Stephen Powers
1978 US 5-Speed
New SoCal928.com Community Site
Old 04-22-2009, 04:58 PM
123 123 is offline
Thanks! And these parts should be from a S4?
Old 04-23-2009, 04:37 AM
Network Native
Danglerb's Avatar
It depends on which oversized brakes you want to replace your fully adequate brakes with, and how much money you want to unnecessarily spend in doing it. S4 brakes can also work with old 1979 parts using an adapter I think, but bigger brakes than the S4 need different options.
Old 04-23-2009, 11:04 AM
928 OB-Wan
Rixter's Avatar
S4 upgrade on mid year car requires 78-80 spindles, new a arms and adaptor...
or you could just swap an S4 suspension on it
78 928 Euro 5spd #34
88 928 S4 AT NachtGrun/GrauGrun
88 928 S4 5spd Guards Red/Black
12 Volvo C30 IceWhite/Black
Old 04-23-2009, 01:44 PM
MPDano's Avatar
Hey 123,
change your title to 1983 instead of 1993. this way future searches won't get buggered up.
Old 04-23-2009, 01:48 PM
123 123 is offline
I get the picture
It Hey 123,
Iīm trying but i canīt seem to open the title in order to change it
Old 04-25-2009, 06:56 AM
