-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   Headlight Problem (http://forums.pelicanparts.com/porsche-928-technical-forum/471546-headlight-problem.html)
EIPtuningR32 04-28-2009 05:27 PM
Headlight Problem
the other day i manually cranked my headlights down. when i was driving around, for the hell of it, i twisted the light knob on the dash and they came up. "WOW!" i said. then i twisted it back and what do you know.... they stayed up. any ideas on what would be causing this? lights go up but not down? i find this strange because to my knowledge isn't the motor a one way motor? doesn't it go both up and down with the same direction of movement from the motor? Thanks -Charles
EIPtuningR32 04-29-2009 02:27 PM
anyone??
MPDano 04-29-2009 02:50 PM
This would be a question for Alan. I'm gonna guess Relay. Is there a relay that is the same as the relay for the headlight motors? You could then switch them out and see what happens.
EIPtuningR32 04-29-2009 04:08 PM
true, but if it was a relay then the headlights wouldn't go up or down, not just up. am i correct?
Danglerb 04-29-2009 06:48 PM
Early cars use a complicated pair of relays combined with a switch in the motor to control the relay. I don't think it "knows" up from down, so maybe you have it unsynced or something. Maybe with the key off and out and lights off, manually lower then lights. Maybe even with the battery disconnected.
EIPtuningR32 04-29-2009 06:52 PM
i have already tried this (not knowing the extent of what would happen and why) and when i switched the lights on, they came up. when i turned them off, again, they didnt go down
Alan in AZ 04-30-2009 11:52 AM
The relay knows if the pod is up or down based on a rotary switch in the headlight motor...
This switch also has 2 diodes to combine a feeder signal from each of the drive signals (go-up /go-down) and runs this through the switch legs (one for pod is not-yet-up and one for pod is not-yet-down).
So the motor is enabled in go-up mode via the relay while the switch indicates pod not-yet-up, it will also drive in go-down mode while the switch indicated pod not-yet down.
The motor is one failure mode - obviously yours works.
The relay is another failure mode - on pre S4 cars its unidirectional - so since it works in up mode its also OK.
The other failure modes are wiring (switch to relay), the switch terminals or a diode.
Most likely are the switch wiper or the diode.
The diode is replaceable (radio shack) and the wiper can be cleaned adjusted manually.
Alan
EIPtuningR32 04-30-2009 12:47 PM
Alan
GREAT ADVISE!!!!! thanks!
MPDano 04-30-2009 01:01 PM
Yup, Alan is the ruler on our Electrics.
EIPtuningR32 04-30-2009 01:05 PM
yeah... i noticed that. he is better than the shop manual!:)
