EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
Headlight Problem
the other day i manually cranked my headlights down. when i was driving around, for the hell of it, i twisted the light knob on the dash and they came up. "WOW!" i said. then i twisted it back and what do you know.... they stayed up. any ideas on what would be causing this? lights go up but not down? i find this strange because to my knowledge isn't the motor a one way motor? doesn't it go both up and down with the same direction of movement from the motor? Thanks -Charles
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 04-28-2009, 05:27 PM
anyone??
Old 04-29-2009, 02:27 PM
MPDano's Avatar
This would be a question for Alan. I'm gonna guess Relay. Is there a relay that is the same as the relay for the headlight motors? You could then switch them out and see what happens.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-29-2009, 02:50 PM
true, but if it was a relay then the headlights wouldn't go up or down, not just up. am i correct?
Old 04-29-2009, 04:08 PM
Network Native
Danglerb's Avatar
Early cars use a complicated pair of relays combined with a switch in the motor to control the relay. I don't think it "knows" up from down, so maybe you have it unsynced or something. Maybe with the key off and out and lights off, manually lower then lights. Maybe even with the battery disconnected.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 04-29-2009, 06:48 PM
i have already tried this (not knowing the extent of what would happen and why) and when i switched the lights on, they came up. when i turned them off, again, they didnt go down
Old 04-29-2009, 06:52 PM
928-Electrics Guy
Alan in AZ's Avatar
The relay knows if the pod is up or down based on a rotary switch in the headlight motor...
This switch also has 2 diodes to combine a feeder signal from each of the drive signals (go-up /go-down) and runs this through the switch legs (one for pod is not-yet-up and one for pod is not-yet-down).
So the motor is enabled in go-up mode via the relay while the switch indicates pod not-yet-up, it will also drive in go-down mode while the switch indicated pod not-yet down.
The motor is one failure mode - obviously yours works.
The relay is another failure mode - on pre S4 cars its unidirectional - so since it works in up mode its also OK.
The other failure modes are wiring (switch to relay), the switch terminals or a diode.
Most likely are the switch wiper or the diode.
The diode is replaceable (radio shack) and the wiper can be cleaned adjusted manually.
Alan
1994 928 GTS Black/Black Manual
Old 04-30-2009, 11:52 AM
Alan
GREAT ADVISE!!!!! thanks!
Old 04-30-2009, 12:47 PM
MPDano's Avatar
Yup, Alan is the ruler on our Electrics.
Old 04-30-2009, 01:01 PM
yeah... i noticed that. he is better than the shop manual!
Old 04-30-2009, 01:05 PM
