Ahdesive for Headliner Material?
If you have been following my posts in the past. I re-vinyled my headliner and used 3M 90 to adhesive it to the headliner board. Well, that lasted about a month and the vinyl has separated from the headliner and is now sagging. What do the pros use to hold material onto the headliner?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
I bought a small can of 3M headliner adhesive at Walmart or Pepboys, but the label isn't still on it (comes off to show instructions under it).
This might be the current product, 3M Super Trim Adhesive, yellow 08090. |
Yup, that's the stuff I just picked up at the Auto Paint Supply store. Will give it a try and report back.
928 OB-Wan
Permatex Headliner Adhesive, comes in a spray can just like the 3m but stands up better to the heat IMHO
78 928 Euro 5spd #34 88 928 S4 AT NachtGrun/GrauGrun 88 928 S4 5spd Guards Red/Black 12 Volvo C30 IceWhite/Black |
Ok guys, I ended up using the 3M Super Trim adhesive and decided to not mount it just yet. I gave it a few days in my garage and it's already starting to peel off. I have a feeling that it doesn't like the vinyl that is still on the headliner. Should the old headliner be stripped off first. It looks like it's on there good.
Yeah, I'd bet that if you're trying to cover the old vinyl with new vinyl you're going to have problems getting it to stick. The vinyl's going to be naturally pretty slick and god only knows what it's been treated with over the years that you'll now never get out of the pores to get proper adhesion. I've used the 3M 90 on all of my panels so far with zero issues (knock on wood) but I've always removed the old vinyl and cleaned the surface to be glued.
What do you use to clean the surface of glue?
928 OB-Wan
Cool, thanks. A weekend project for sure.
1982 928 us
3m super trim adhesive 20 bucks a can too would think its the next strength seems all it does is spray out crazy and dry quicker still wont take to the old vinyl a quarter panel has shrinking pulled away from its edge between quarter window fixed it once while panel was out now its a b**** too get a pull on it wrap the edge get fingers in behind and lucky if i can spray one side forget a layer application to both sides and for it not to stay i did rough sandpaper surface and back of cloth to try to get some napp on it and acetone clean all surfaces, failure on that one know all messed up again with more glue. installed and still needs fix.
Network Native
Once the vinyl shrinks, there is no stretching to fix it, just new vinyl.
What kind of adhesive really works with different materials seems a bit of a art, so I am thinking about letting somebody else do it, but maybe not. Could be the "art" is messing up enough times until somehow you get lucky? |
1982 928 us
hot sun for both vinyl pulls a bit more warmed up just enough in my case and sun for glue too yeah its an art alright right amt to put on right amt time to set up and right amt of time to stick but this one proj is sticking it to me
not a happy task just so not a spray can person anyway spray cans new or old screw up , no matter whats in them one push on the button the wrong way forget if your finger gets tired and can is toast. can take some of the panel form edge down , color screws, super glue, try luckyness on another day with patience and time |
I hear ya. I think
Network Native
I have a trigger thing for spray cans. Clips on and saves fingers from goop and wear and tear.
I don't like bonus screws in my trim, just use some new material. |
