Gas Tank Leak
Noticed a gasoline smell this morning in the garage. Later found out that there is a small visible crack on the bottom of my tank near the front strap that holds the tank in place. Right now the drip is very slow and small. What is the best way to make a repair? I do have a heat gun that can weld plastic, but I'm not sure what type of plastic the tank is made of. Or if another method may be easier? Any suggestions?
Old 05-15-2009, 08:25 AM
Network Native
Danglerb's Avatar
Replace it.
At the very minimum the whole tank needs to come out and be CAREFULLY inspected for further damage, and a source of what caused this problem.
New tank is about $950 I think, used tank depends on who has one in your area, maybe $150.
Old 05-15-2009, 11:06 AM
MPDano's Avatar
Sure you can repair it. I mean, it's just a ticking time bomb behind your head.
Do what Mikey said, replace it!
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-15-2009, 11:13 AM
Network Native
Danglerb's Avatar
The reason I say replace it is normally the tanks are very robust, even old ones are fine. My concern is that something damaged your tank, and this leak may be just the first signs of greater issues. 23.5 gallons of gas makes a heck of a fire, its not worth the risk.
Do try to find the source of the damage, otherwise the same thing could damage any new tank.
Old 05-15-2009, 11:21 AM
MPDano's Avatar
Originally Posted by zl287hihi317 View Post
去年的吸血鬼卖座大片*spam*动作电影/暮光之城/]《暮光之城》[/url]的续集《暮光之城:新月》,昨日曝光首张剧照 ——群“狼族”青年赤膊亮相:查斯科·斯宾塞、亚历克斯·莫拉兹、凯欧瓦·高登和布朗森·佩尔提埃。他们将 在本片中加入泰勒·拉特尼尔阵营。这群狼族青年和“素食”吸血鬼阵营完全不同,体温高达108度,仿佛是从 健身房刚刚出来。
All those letters just to say "Hello?"
Old 05-15-2009, 11:34 AM
Super Moderator
nize's Avatar
was a spammer, post and account deleted.
'89 turbo-s (2.7, wolf3d ems, garrett dbb turbo, tial 46mm, etc. fast!)
Old 05-15-2009, 12:24 PM
Replies
Thanks to the group for the replies. I just about have the tank removed. Have it drained and hoses etc. loose, just two bolts and out she comes. A close inspection only showed the small stress crack. I remember reading on one of the sites some time back that where mine has the crack is a common spot. There was no contact with a foreign object or any scrape marks.
Old 05-15-2009, 12:35 PM
MPDano's Avatar
That's good news as far a your research on the stress crack. Also, nothing foreign near to crack it. If your going used. Make sure you get one that will be guaranteed. ie; 928 Intl, 928 Worldwide, etc. Also, if you get a used one it's not clean, just take it to a radiator shop and have them acid wash it before putting it back in. New hoses and seals.
Good luck and keep us posted
Old 05-15-2009, 12:38 PM
MPDano's Avatar
Pics of my tank before and after.
Old 05-15-2009, 12:42 PM
Network Native
Danglerb's Avatar
The single bolt at the aluminum tab near the filler is "the" support for the tank, remove it last.
Old 05-15-2009, 08:19 PM
I have a used 88 tank off my parts car (courtesy of my teenage son - the parts car that is). But I think they are repariable, like you, I saw an article by someone that repaired a tank.
Old 05-16-2009, 08:04 AM
Network Native
Danglerb's Avatar
I agree "it can be done", I am just suggesting it is ill advised. My thinking is that it is a judgment call whether or not to replace it with a new or a used tank, but a used tank that shows no signs of damage and holds pressure etc. is my minimum. All the hoses and rubber parts need to be new, as well as the cushions on the support frame.
When we buy a used 928 pretty much nobody preventively installs a new gas tank. If keeping the used tank that comes with a used 928 that hasn't been removed and inspected is OK, then replacing a bad tank with a good inspected and cleaned one is OK too.
Old 05-16-2009, 09:07 AM
Repair Made
Someone suggested to me a product called "Seal-All", which I have applied following the directions. This is an adhesive product which is flexible and designed for such repairs. I applied three layers of the product with a strip of metal laminated between two of the coats. I will test for any leaks prior to the re-install. I hope to install the tank in a few days, this will enable me to get the car running while I look for a replacement. I'm pretty sure a friend has a replacement. There was some corrosion on the tank support bracket where the pressure line and electrics are nested going to the filter and pump. I'm cleaning that up and painting prior to assembly, also installing new foam pads and hoses.
Old 05-18-2009, 05:11 AM
MPDano's Avatar
Mike, why would you post that? I just recently got over the PTSD that image created for me. Why??????????
Old 05-18-2009, 08:52 AM
Network Native
Danglerb's Avatar
Post what leo? Maybe your not so over it?
Old 05-18-2009, 09:06 AM
MPDano's Avatar
Dang, I'm getting old and senile!
Old 05-18-2009, 09:12 AM
