-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   What else do I need from Roger? (http://forums.pelicanparts.com/porsche-928-technical-forum/477528-what-else-do-i-need-roger.html)
Danglerb 06-01-2009 10:00 AM
I'm getting a new front spoiler for my US 83, but I can't remember what else I should be getting from Roger at the same time (not something spoiler related, I would remember that), but some odd bit that only Roger has?
I've already done the fuel and vacuum lines, have a silicone oil pan gasket, motor mounts, and most of the vacuum pods. Pretty sure I remembered something else this morning, but I forget what it was.
Alan in AZ 06-01-2009 10:40 AM
VW interior lights?, fuel lines?
Alan
Danglerb 06-01-2009 10:43 AM
Roger has the neat black VW interior lights?
Mike B 06-01-2009 03:08 PM
Was it some the new products he has recently released?
The Racing Timing Belt, http://forums.rennlist.com/rennforums/928-forum/500966-new-product-from-928srus-racing-timing-belt.html
The PKlamp & Hatch Receiver Insert, http://forums.rennlist.com/rennforums/928-forum/498135-new-pklamp-and-hatch-receiver-insert-from-928srus.html
or the Solid Rack Bushings, http://forums.rennlist.com/rennforums/928-forum/492243-high-quality-solid-rack-bushings-new-product-from-928srus.html
Barbapapa 06-01-2009 03:16 PM
Oil pan spacer kit?
Danglerb 06-01-2009 04:16 PM
I was just loading my new set of Bilstein shocks into the hatch and bingo, hatch receiver insert.
Good guess MikeB (by naming everything, very tricky)
New Gates belts aren't ready yet are they?
Anything else?
Does Roger have some kind of new 16v cam tower gaskets or seals?
Mike B 06-02-2009 05:01 PM
I thought I would toss out all I read...Not sure about the 16v stuff as I'm on the other side :)
I do know this...most stuff Roger comes out with I already picked up...which naturally costs more... just my luck!
Still have my sights on the steering rack bushings though.
Danglerb 06-02-2009 07:02 PM
So far
Front spoiler
Hatch receiver insert
Cam tower silicone gaskets
I thought about a steering rack rebuild kit, but what are these bushings? Rack to cross member?
Mike B 06-04-2009 04:21 PM
Originally Posted by Danglerb (Post 4699015)
...but what are these bushings? Rack to cross member?
Mike, yes...that is my understanding. Feedback is they are a substantial improvement over the oil soaked rubber pieces. i haven't priced out the OE parts but I'm guessing they're more than these.
Landseer 06-05-2009 02:10 AM
I've got a set of aluminum ones on an 84 that really do take play out of the steering. Now is the time to do it if the rack is coming down. Easier to take the rack off completely to remove the old rubber / metal units.
Are there silicone cam cover gaskets?
If doing cam cover gaskets, then, you would want the cam shaft seals, nose O-rings, and little thick O-rings that mate the Mickey Mouse ears to the cam covers. And the distributor oil seal.
Danglerb 06-05-2009 11:04 AM
I ended up with;
Front spoiler, hatch receiver insert, set of silicone cam gaskets (nothing for main gasket, just the ends), and a steering rack seal kit.
I wish Roger had at least a new product display page.
MPDano 06-05-2009 11:25 AM
Ok Mike, now I really must see that Spoiler you bought when you get it. Pics a must.
Alan in AZ 06-05-2009 01:00 PM
Yes he has(had) them in black, grey & tan. He also has the VW connectors on pigtails.
Danglerb 06-05-2009 01:03 PM
I don't think so Leo, nice new spoiler, I'm taking it off when I drive to SD. ;)
MPDano 06-05-2009 01:06 PM
Do they have Bras for those Spoilers so you don't get any nicks in them while cruising on the Interstate 5?
devilinblack 06-05-2009 04:41 PM
Good luck finding a bra that will prevent "nicks" from the ladders, paint cans, buckets and humans one is likely to come across (run over) on the 5 between OC and SD.
Danglerb 06-05-2009 10:42 PM
I still plan to put on a baja plate, but that leaves the virgin spoiler out front to get spoiled.
MPDano 06-06-2009 08:20 AM
...and the occasional Coyote or Possum.
