vdubr928's Avatar
Someone with an x-pipe
I am going to be building my own x pipe soon unless I can find something cheaper. I need to know where to put the x. Maybe someone could mesure say from the bell housing for meto the center of the x?
Old 06-09-2009, 07:53 AM
Petie3rd
Mrmerlin's Avatar
your best bet would be to buy one that has already been tested and manufactured.
Many hours went into development of these pipes and just fabbing one up may not give you the most HP, if you want to try then go ahead .
For the money its the best upgrade, Roger sells them and Motorsport in Utah makes them, goodluck, Stan
Old 06-09-2009, 08:06 AM
Bay Area Patriot
TheStig's Avatar
Start with this like I did. Works the same...
ANY, I repeat, ANY form of an X-pipe will generate more HP than the factory balance pipe, or H-pipe.
http://cgi.ebay.com/ebaymotors/T304-STAINLESS-STEEL-UNIVERSAL-EXHAUST-X-PIPE-2-5-NEW_W0QQcmdZViewItemQQ_trkparmsZ65Q3a12Q7c66Q3a2Q7 c39Q3a1Q7c72Q3a1205Q7c240Q3a1318Q7c301Q3a1Q7c293Q3 a1Q7c294Q3a50QQ_trksidZp3286Q2ec0Q2em14QQhashZitem 3ef5498ac9QQitemZ270403209929QQptZMotorsQ5fCarQ5fT ruckQ5fPartsQ5fAccessories
Andy
1987 928 S4 - 3" Single Exhaust after cats
1999 Mercedes C280 Sport Package
2003 Mercedes ML350
Old 06-09-2009, 11:06 AM
Network Native
Danglerb's Avatar
Two main factors on a merge pipe, distance to the valves, and geometry of the merge pipes, but I suspect your right, anything is better than factory.
Old 06-09-2009, 12:37 PM
Is there any cheaper H.P. to be gained on a 928? Exhaust tuning is a science and should be backed up by a lot of testing. Subtle angles and joints can make big differences in the flow of gasses. A well tuned exhaust system really sounds *****en as well.
1986 911 Carrera POC JI/R7
1989 928 S4
Old 06-09-2009, 08:40 PM
vdubr928's Avatar
Ok thanks for responding. Here is my problem. The pipe broke at the forward muffler. (I guess the rear hanger fell off) Pretty damaged from there back. I can do the welding and the bending but, I was thinking of buying a pre made x like the one pictured above. Where should I locate the x and also I was wondering what to do from there. I was thinking about going straight back to the rear muffler well and either using two mufflers or a dual muffler. I was hoping for some pics of a well set up car so I will have a visual blueprint. And your opinions as well.
Thanks,
Carl
Old 06-09-2009, 09:50 PM
vdubr928's Avatar
By the way... Who makes a nice complete system?
Old 06-09-2009, 11:16 PM
Network Native
Danglerb's Avatar
This place does nice work ...
http://www.burnsstainless.com/Crossovers/crossovers.html
Old 06-09-2009, 11:48 PM
vdubr928's Avatar
What about a complete 928 dual system that is built for street?
Old 06-10-2009, 10:29 AM
Try here...
http://www.928exhaust.com/
Old 06-10-2009, 10:48 AM
Network Native
Danglerb's Avatar
Dual vs single is a piping problem, no inherent advantages except that dual cats might flow a bit better than a single cat, but they also might have some effectiveness issues due to the reduced flow through each cat.
Piping is all about the square inches of cross section, and number and type of bends. Models with a big battery box may not be practical to run two pipes to the rear, but nothing to stop you from running one pipe and using a dual outlet muffler for show.
Old 06-10-2009, 11:09 AM
Bay Area Patriot
TheStig's Avatar
Saw a dyno a while back on Louie Ott's site that shows that a 3.5" single pipe GT dynoed more than a dual exhaust with x-pipe.
Andy
2003 Mercedes ML350
Old 06-12-2009, 10:51 AM
MPDano's Avatar
Interesting. I assume no cat.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-12-2009, 10:54 AM
Bay Area Patriot
TheStig's Avatar
I don't remember if it had a cat on it or not.
Still can't wait to dyno my weld in. I still need to shark tune it prior to getting any real charts showing numbers. All in all, I'm still very happy with the weld-in and the larger piping. Much more pull than before and only a $350 bill for exhaust from the manifolds back.
Andy
2003 Mercedes ML350
Old 06-12-2009, 11:01 AM
