BB500's Avatar
raer side glass
anyone know a trick to getting the rear side glass out without damaging the rubber?
Old 06-15-2009, 10:39 AM
MPDano's Avatar
Break the glass. Perfect rubber seal will appear.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-15-2009, 11:18 AM
1982 928 us
portia's parts restoration kondratyev
loaded with info/tips may take a bit of clicking around there forgot to remember just where in there and clicking steps. like click technical ,exterior, glass, qua glass (removal steps and pics) not my first choice ....
ive seen another one thought it was this site but was using the wire method although would have been install, where you put seal on glass lay wire insert glass and from inside pulling the wire around will catch and pull the lip on seal sealing window in.
Old 06-15-2009, 11:30 AM
Network Native
Danglerb's Avatar
Good used rear quarter glass is cheap, seals are expensive. If your seals are good, not 30 year old artifacts, break the glass and keep the seals. If the seals are old and need replacing anyway, cut the seal and save the glass.
US 83 zinc metallic 5 spd, aka the nice car.
Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD
Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years.
Old 06-15-2009, 11:42 AM
MPDano's Avatar
This is install and NOT removal. I used this trick to install and it worked flawless.
Old 06-15-2009, 11:45 AM
BB500's Avatar
What??? My rubber is like new, but I still don't want to replace the glass. I'm going to fool around with it, if I'm able to get it out safely, I will let you know how to do it...
Old 06-15-2009, 12:11 PM
1982 928 us
correct thought where ive seen the install it being easy peasy flawless that an easy unistall could be found and easier than the PORTIA'S PARTS RESTORATION removal its there if you go the route of saving glass and seal. Most do pick the seal or glass and do the install if you get seal removed and are ok i have 2 for one clear 78euro quarter glass if you want it.
Old 06-15-2009, 12:19 PM
BB500's Avatar
I just noticed I can't spell...
Old 06-15-2009, 12:20 PM
1982 928 us
rear glass
no comment on the fuchs the phone dials were sold and 67 912 is on blocks restoration and took and threw these on to be able to move it about still. anyway heres clear 78euro quarter glass if int.
Old 06-15-2009, 12:32 PM
MPDano's Avatar
Well, there you go Blythe. lfausty has one for you. Break out the hammer.
Old 06-15-2009, 12:38 PM
Petie3rd
Mrmerlin's Avatar
to remove the quarter glass first remove the plastic trim thats pressed into it spray soapy water on the plastics so they dont rip the rubber when you remove them , dont bend them they have a metal band inside them. then working from thew top corner inside the car gently push the rubber portion of the seal inwards to the window with your helper hold the glass work you way along the top of the seal gently pushing it this will begin to release the rubber and the whole glass rubber can be lifted out.
If the rubber is boded to the window frame then you may need to fit some mechanics wire through the seal to body, to cut the bonding, use WD40 if you go this route to help soften the sealant
Old 06-15-2009, 01:01 PM
1982 928 us
yeah but seems to want to save both flathead screwdriver - spacers for in between body and gasket (use flooring spacers,home depot) lots of liquid, greasy ones, not of the alcohol type again portia's parts restoration - click technical , exterior, glass, qua glass for removal you didnt ask if possible you ask for tricks -- i dont think so -- time and skill seems the best your gonna get no trick there , but possible to do, yep.
Old 06-15-2009, 01:10 PM
1982 928 us
your post went up whilst i was typing - NICE - Mrmerlin
Old 06-15-2009, 04:29 PM
Network Native
Danglerb's Avatar
Maybe this is a job for some Astroglide or whatever supper slippery type stuff?
Maybe a couple of those nice big suction cups they pull out dents with?
Set of plastic pry bars?
Old 06-15-2009, 09:00 PM
1982 928 us
and a partridge in a pear tree since were off season and have become politically correct, dont offend other religions on and on how about and a WHOPPIE PIE
crap cakes !!!!! you know the elementary school has sent out notices from those pisst off parents that dont want to let there kids oop children have a piece of cake or a cupcake when they celebrate bday in class room wouldnt want those 5 yr old 25-30 lb ders climbing walls,sugar diabetes or get obeast. How about the cakes made out of prunes, what there good for you, youll satisfy them all.
HOLY CRAP and i mean holy crap and its just starts all over again dont it
Old 06-18-2009, 07:31 PM
Petie3rd
Mrmerlin's Avatar
Ifausty, where are you ?
What language is your primary language?
Just curious ,Because your post content is really BAZZAR???
Old 06-18-2009, 09:16 PM
Network Native
Danglerb's Avatar
Its a crazy world, I KNOW Twinkies are out to get me, but an innocent little cup cake?
I blame the frosting, except I know how many calories are in carrot pudding, and one can hardly blame a carrot?
If you break the glass or cut the rubber is the window half full or half empty?
Old 06-18-2009, 11:15 PM
MPDano's Avatar
lfausty, man you crack me up. Sometimes we just need to have fun and let loose.
Old 06-19-2009, 06:51 AM
Petie3rd
Mrmerlin's Avatar
If you have not tried them I recommend that you get some Tasty Kakes, made in Philly PA.
I like the Butter scotch Krimpets and the Peanut Butter Tandy Kakes......
Way better than cup cakes, twinkies, crap cakes, carrot cakes, prune cakes......
What this has to do with rear quarter window/ seal removal is beyond me????
Old 06-19-2009, 07:53 AM
Network Native
Danglerb's Avatar
Balanced nutrition is always important, especially when removing rear quarter windows.
The most popular pro glass guy seal tool.
http://www.dkhardware.com/product-909-cp253-general-purpose-windshield-and-back-glass-rubber-installation-tool.html
Search for glass lubricant at your own risk.
Old 06-19-2009, 08:50 AM
