Flexplate...
I'm going to go check the tension on my flexplate right now and try to solve the grumbling noise/stalling.
wish me luck........ |
Network Native
Link to Bill Balls thread on how to do it.
http://forums.rennlist.com/rennforums/928-forum/361453-my-flexplate-crank-endplay-check-pictorial.html
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
victory!!!
Well, sort of.... I'm starting a new thread for help on the subject
Petie3rd
if this is your first time of checking the front pinch bolt make sure to check the rear pinch bolt as well, I have seen more than a few of the rear bolts loose or just snug.
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
So what does this mean Blythe? Did you get your Fuel Distributor sorted? I was going to see how things were going tomorrow. What's the verdict?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Network Native
Flex plate was related to the car that is now sold. I'm not sure if it ever did get checked.
Bay Area Patriot
Is there a piece to remove in the back to check the rear pinch collar bolt? I don't remember seeing one back there; then again I never really looked as I was dealing ATF leaks coming from the bottle at the time.
Andy 1987 928 S4 - 3" Single Exhaust after cats 1999 Mercedes C280 Sport Package 2003 Mercedes ML350 |
Ah, I didn't see the posting date.
Network Native
All the info should be in the link in my second post to Bill Ball's guide.
Petie3rd
to get to the rear pinch bolt the exhaust must be dropped and the center heat shield must be removed and then there is a small rubber plug in the rear bottom of the TT, pull the plug and then turn the engine till you can see the bolt head.
set the torque wrench to 66ft/lb and then remove the bolt and see how much it takes to turn it,once the bolt is out check the shanks for wear this will happen if the bolt was loose and is caused by the driveshaft moving in the coupler. If the bolt is damaged then replace it with the correct bolt IIRC its a hi strength bolt 12.2 . Center the driveshaft in the trans input shaft coupler then tighten the bolt. Then tighten the frotn bolt after prying the flex plate/flywheel back
