Petie3rd
Mrmerlin's Avatar
need a lock cylinder for the drivwer side
I am looking for a used lock cylinder for the drivers door I need the little ball fitting that plugs into the plastic arm inside the door, no key is necessary, this is from a 86 with alarm.
Thanks Stan
Old 07-07-2009, 12:33 AM
I have a '78 & had almost the same problem. The plastic linkage that goes from the lock mechanism to the lock cylinder was broken. I went to the local hobby shop & got a threaded rod & set of tie rod ends from a Tamiya on road RC car. The ball cup size was a perfect fit. The ball studs can also be purchaced. Maybe buying a simple ball stud from an RC car would save you from buying a lock cylinder?. I hope this helps you.
Old 07-07-2009, 03:56 PM
Petie3rd
Mrmerlin's Avatar
No good, I need a ball stud and it is part of the lock cylinder the old one cracked in half.
Old 07-07-2009, 05:42 PM
Did the arm comming off the lock cylinder crack in half or did the ball stud?
Old 07-07-2009, 06:43 PM
Petie3rd
Mrmerlin's Avatar
well its the arm and the arm is actually a round and fit inside the lock cylinder and around the key barrel, I was going to try a silver solder.
UPDATE I think i got one, Thanks for you concern, Stan
Old 07-07-2009, 07:10 PM
