Auto Tranny Vacuum Sound when put in gear?
I have an 81 with a 3 speed auto. When I put it into gear, it sounds like vacuum leaking from the rear. Also, when I accelerate, you can really hear the vacuum or air pushing from the rear of the car. Any ideas what this is or is this normal?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Heavy Metal Relocator
is it a vacuum line?
or an exhaust leak? --Russ
Absence of Evidence, is not Evidence of Absence. Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma." |
Network Native
Isn't there a vacuum line that runs back to the tranny?
Here is the video of when I got it running on all 8 cylinders. You can hear is as I accelerate away.
http://www.porsche928forums.com/videos/928_12.26.2008.wmv
Network Native
That sounds like intake noise, like running without the air filter.
US 83 zinc metallic 5 spd, aka the nice car. Euro 85 black, 5 spd, the fast rough track car maybe car. SOLD Euro 84 red, AT, only car in garage in years, my parts car, soon to go last 7 years. |
Your right, I do believe I was driving without the air box that day. I guess I should try it with the box on. It just sounds like it's coming from the rear of the car. Could be the exhaust fumes getting to me.
I still get that noise (vacuum) coming from the rear at takeoff and when putting in gear. Anyone else with an Auto can verify that theirs does NOT make that noise?
Petie3rd
instead of guessing just get the car jacked up and then look at the driver side of the trans you should see a vacuum line connection to the vacuum modulator, start the engine and listen, then pull the line off and see if its sucking, no sucking means a break in the line , it runs along the top side of the TT up to the a connection at the rear of the engine
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Pass side on your 81 3 speed. Not sure about other years. The vacuume line that feeds the modulator is metal most of the way back. There is a 3 inch section of rubber hose at the modulator on the pass side of the trans. There is no reason you would hear an increase in leakage (if it is leaking) when you hit the gas. Actually you would hear more at idle as there is more vacuume available at idle than for the first few seconds of balls out throttle. You must be hearing something else but if it makes you feel better pull that vacuume line and check for leaks. A cheap section of line from napa will verify the line is not the prob. Chack for trans fluid in the old line to verify the modulator is not leaking. If neither of these problems are present then you can rest assured that you are hearing something else. Leaky Cats can cause an airy sound.
Do you have a vacuume pump for testing? Pull the line at the engine and test for leaks. Very simple system that Mercedes used since the late 60's not much can go wrong here. The Porsche part isn't even adjustable on my 82 so there is even less going on here than what I'm used to. Line is easy to find since it's the metal one that goes to the intake.
My vacuume tester looks like this and doesn't work worth a crap to bleed brakes but is a great auto vacuume system tester. (since it will show loss) You should not have any loss through here and if you pull the line at the engine and see tranny fluid then you have a bad modulator. Does the car shift smooth? If so you probably don't have a modulator problem since it controls shift pressure. |
Petie3rd
vacuume is spelled vacuum
Nope, Gore spells it with an "e" at the end, so it must be correct.
40 or so
Normal should be around 30. If you want to be sure check what you have coming off the metal side at the rear of the engine. This will not only tell you what to test at but also you can check at the trans with everything hooked up and make sure your not leaking somewhere in between. ie. you should have the same at the modulator as you have at the junction near the bell housing. If you have good readings, car shifts smooth, and no tranny fluid in the lines then you are hearing somthing else or a leak from somewhere else. Last edited by vdubr928; 07-07-2009 at 09:48 PM.. |
Thanks and I will give this test a go when i get a free chance. Can you watch the video I posted? You can hear the vacuum(e) sound or some noise.
MPDano,
I watched your vid. and thought I did hear something like a whoosh sound not a sucking vac. sound. (that sounded stupid) In any case I did hear something that I dont hear w/ mine 79US auto. I see you have replaced the vac. line to trans. already, that is the only vac. line going theree, but it could be the modulator itself. The test described in other post should determine this. You are really just trying to find out if there is a break in the line from the plenum to modulator. Good luck, John
"Por ' sche" is a two syllable word. "79" US |
Ok, I did watch the vid. Are you running without an air filter in this vid? Or do you have a cone filter upgrade? It "sounds" like you are pulling allot of air from somewhere. (diagnosis by video is never that accurate) That being said here is my opinion.
Pull the modulator line off the trans. Drive the car....... Does it shift rough? Do you notice a pretty big differece in the way the trans shifts? Is it unpleasent? Probably you are going to answer yes to all of these. If so... Forget testing the modulator, It's working. (you checked for trans fluid in the line when you pulled it... A very rare failure on these) Ok... Now we know what it is not. No other engine vacuum* goes to the rear and I will be honest with you. If the air leak is as big as it sounds it is pre AFM. You could check the brake booster but if it is leaking (that bad) you would need a floor jack pushing on the brake pedal to stop. Pre AFM means check the air box. If you have a leak post AFM that was sucking as much air as it "sounds" like you are then the car would run very poorly. (Read probably not at all and no way it would idle) Best way to find an airleak is a can of carb cleaner. start spraying near where you hear the sucking sound (that sounded stupid LOL) and when you hear engine RPM's drop then you founds your leak. Start at the airbox. |
