See if you can get a used part from one of the used parts places. Bang it on the ground and see if a possum crawls out, or just replace with one off the other car. |
black smoke to rich, fix? is the exhaust system which is complete soot still burning off black, cause with muf on the smoke is only lt grey
if was causing restriction the pipes inside black sooted condensation and the black smoke from there will it clear? . that was the other 78euro muf the 82 was completly blown out huge hole on tire side of it maybe prob began there. there is a seriously seriously small oil leak eng comp. but think not enough that its not causing this much exhaust trouble. got to get the hose back on and aircleaner run it more with muff off still again? ???? |
I think this shows the parts (c/o DC Auto)
27 928.113.136.00 $49.05 Air tube /R 27A 928.113.146.01 (81-) $61.54 Air tube 28 928.113.135.03 $27.82 Air tube /L http://forums.pelicanparts.com/uploa...1247776178.jpg |
all parts you list check out its 24 that is needed but nla part, all parts after taken 24 hose off whole setup went right down to ground are you saying that what holds it up from completly falling through , 27a on the top there is bracket that would bolt up, to (frame or wherever its suppose to attach too.) so it stays up, ill attach it
when i get to the end of fallen through 25 setup the pipe end is clamped at the end with rubber hose piece and another clamp, no 32 piece? and it attaches to a same type pipe as the 25 setup coming from along beside the cat it would be after 31 and not showing. wobbly rubber hose conection there ill check if 32 correct for replace and fix. |
fixed fixed and fixed thanks muchly im am driving ALL SET!!!!
was diverter hose and under car where other end attaches issue, and muffler restriction bit of idling and all good warm to op temp and shut car off wont start again til cools , ALL SET!!! issue my brake lights decided not to work now, master cylinder switch, looking into will fix. ? about it yep im sure, will search out any answers or begin a new thread. brake pads need to be looked into too. |
| All times are GMT -8. The time now is 10:05 AM. |
