bolt queston
What size is the bolt at the front of engine that holds the pulleys on?
I've gone trough all my sockets and they're all to small.
Old 07-26-2009, 10:43 AM
Petie3rd
Mrmerlin's Avatar
27mm deep, use a 1/2 in. drive
Old 07-26-2009, 11:34 AM
MPDano's Avatar
Also, remove your Fan for more clearance. Also make sure you have an extension for that socket as you'll bend the crap out of your pulley if it doesn't clear. Ask me how I know?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 07-26-2009, 12:07 PM
Petie3rd
Mrmerlin's Avatar
a 27mm deep will clear , if you use a short socket then yes you need the extension
Old 07-26-2009, 12:45 PM
vdubr928's Avatar
At least 180ft lbs of torque on that bolt. You will need something to lock the flywheel (they make a tool but i used a friend with a big flatblade) and probably a long pipe that fits over your rachet.
Old 07-26-2009, 12:47 PM
Network Native
Danglerb's Avatar
Use an impact wrench if you have one.
Old 07-26-2009, 04:20 PM
thanks guys. I've also ran into another snag. The head for 5-8 clyinder bank is stuck on. I've removed all the hardware, and doubled checked everything. But it won't budge. Any ideas?
Old 07-26-2009, 05:32 PM
Petie3rd
Mrmerlin's Avatar
bolt the exhaust manifold back on and try prying the inside of it up wards with a 4 ft long piece of 2x4
Old 07-26-2009, 06:19 PM
