ignition key positions
Ok here is a strange one.
1987 928S4
I can turn the car off... ignition off... power off to everything except radio and pull the key out. So the radio is still on. Even if I get out of the car.
But here is the strange thing. I can also turn the key to another position which turns off the radio and still pull the key out from this position. Is this typical?
82 924 restored, 83 944 parting out
In search of 1988 or newer nice 944.
Old 08-26-2009, 11:00 AM
american-kiwi's Avatar
my 82 does the same...i have left the radio on all night, at times
John .........
1978 Porsche 928 5sp LSD
1982 porsche 928 5sp LSD
Old 08-26-2009, 11:22 AM
Petie3rd
Mrmerlin's Avatar
first have you checked the ignition switch on the back side of where the key is inserted?
The screws might be loose.
If its tight then you may have uncovered a failing ignition switch
Old 08-26-2009, 04:07 PM
Ok how does one take out the switch? also what screws loose?
Old 08-29-2009, 07:27 AM
928-Electrics Guy
Alan in AZ's Avatar
No thats a problem, something isn't right.
Key should only remove in the 0 position - everything off
Position 1 accessories & radio
Position 2 ignition on
Position 3 Starter
Alan
1994 928 GTS Black/Black Manual
Old 08-29-2009, 12:47 PM
Petie3rd
Mrmerlin's Avatar
I have seen the key be able to be removed from the lock cylinder in other than off positions, either the key is worn or the lock cylinder is worn or both. Try spraying some WD 40 into the ignition cylinder not much.
Also try another key
Old 08-29-2009, 01:10 PM
