MPDano's Avatar
Switch on AC Drier?
Is this switch a Pressure or Temp Switch, which turns the Electric Fans on? This switch is mounted on top of the AC Drier.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-23-2009, 07:33 AM
rjm65's Avatar
Switch on the drier is pressure and can turn on the electric fan. There's another switch on the block that is temp, and that can turn on the fan too.
If you look at the switch on the drier, you'll notice it looks just like the pressure switches that work the brake lights (near master cylinder)
Old 09-23-2009, 12:57 PM
MPDano's Avatar
The reason I asked the question was because "where is the pressure from?" It's not the internal pressure from the Drier since the Switch screw was not capped and there was pressure in the Drier before i released it to install it.
Are you sure it's pressure?
Old 09-23-2009, 01:32 PM
rjm65's Avatar
Here's the link to the pressure switch, then click on the images tab, then scroll down to the parts diagram.
That's the switch you're asking about right?
Old 09-23-2009, 02:00 PM
Recovering dismantler
neil30076's Avatar
If there is a small hole in the center of the switch its pressure, otherwise temp.... from what i recall, having replaced it a week or so ago, its pressure to turn on the fan if presuure goes up in system.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 09-23-2009, 05:10 PM
MPDano's Avatar
Ok, I think I recall it having a hole in the switch, but "Where" does it get it's pressure? Like I said, there was "No" cap on that threaded area that you thread the pressure switch on. There "Was" pressure in the Drier before I released it, to install the Drier.
Old 09-23-2009, 08:38 PM
