MPDano's Avatar
A/C Compressor and Drier R&R
Ok, got the Compressor that I got from Neil checked out by Eskimo A/C here in El Cajon, CA. Compressor is good to go. This weekend I am going to R&R the Compressor and Drier and new O-Rings I also got from 928 Intl. I do have a question about where those O-Rings I got go. I am assuming I will figure it out as the hoses are removed. Correct?
FYI, after I install the parts, I will then be taking it back to Eskimo A/C to do the Flush, Evac and Fill with R134.
Thanks again Neil for the Compressor, it cleaned up real well.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 09-10-2009, 06:26 PM
Petie3rd
Mrmerlin's Avatar
take off the inlet ports on the compressor and verify the O rings look new. ( there should be 4 of them)
I would also wonder if they put oil in the compressor so its ready to go. SB about 5 oz.
Also i would take both of the flex lines that connect to the compressor to the hydro store and have new hoses crimped on, if you have originals its a safe bet they will leak and you will be doing this job in a few months.
Next to check is if you have rear air, remove the top cover for the AC unit and look around the front where the lines go in if it looks oily then the O rings need to be replaced / And/ or the rear evaporator is leaking from where the copper lines are crimped into the aluminum.
Also check under the car where the lines feed into under the passenger seat if the bottom of the car looks dirty around these fittings then these o rings are also leaking and should be replaced.
Remember dont over tighten the lines, usually just past snug is tight enough.
Old 09-10-2009, 07:32 PM
Petie3rd
Mrmerlin's Avatar
If they are doing a flush i would not connect the compressor to the lines and leave the receiver drier off till your done with the flush.
The receiver drier is the last thing thats connected prior to pulling a vacuum on the system, you should go through the whole system and replace the expansion valves and all of the other connections with new 134 safe rings, this also includes the fuel cooler
Old 09-10-2009, 07:38 PM
Recovering dismantler
neil30076's Avatar
Leo, just did this -
10.6 mm O ring is both ends of long hose to evap coil.
14 mm is both ends of shorter hose.
7.5 mm is top of dryer to hose.
BTW, nice clean up on compressor.
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 09-11-2009, 08:52 AM
MPDano's Avatar
Is this 5 O-Rings? If so, the 4 I got from 928 Intl is incomplete. Also, wrong sizes since they are all different sizes.
Old 09-11-2009, 11:31 AM
MPDano's Avatar
Ok, after doing some Recon on my R&R tomorrow. I released the pressure from the system and was looking at what will need to be removed. I see the Drier is very close to the Condensor, will anything need to be removed to get to the hoses and Drier?
Old 09-11-2009, 04:00 PM
Hey,
I tried to change out my o-rings from that same kit from Intl, Same problem, it did not look like enough to replace all of them and there was no way I could tell where they went.
The old rings I found that did not match those in the kit, I took to NAPA and matched there.
Worked for me.
Chris
86.5 928 Indy Red/Black, A/T, 118,456 miles and counting
Old 09-11-2009, 06:45 PM
MPDano's Avatar
Grrr. I think I may just mount the Compressor and Drier and have the AC Shop supply the O-Rings and hook the hoses up. It may be better unhooked anyways since they will need to flush the system.
Old 09-11-2009, 07:06 PM
MPDano's Avatar
Ok, the hard work is done and next step is to drop off at the AC Shop Monday or next weekend. Here's the pics of the Compressor and Drier installed. I really like the newer design Drier as it puts the High Side fitting up high and more accessible. I guess the hardest part was getting the Compressor hoses and O-Rings to play nice. They O-Rings just kept wanting to squeeze out and if that wasn't enough, just trying to thread the nut back on.
Also, before I put it all together, the AC Shop suggested that I blow out all the hoses using an air compressor to get any debris out.
Old 09-12-2009, 02:32 PM
MPDano's Avatar
Old 09-12-2009, 02:35 PM
MPDano's Avatar
I also ended up using 3 or the 4 O-Rings sent by 928 Intl as they all fit perfectly. I just didn't use the last black one since the new Drier had a new green o-ring, so I used that one instead. So 4 new green o-rings were used in this project.
Old 09-12-2009, 02:38 PM
Petie3rd
Mrmerlin's Avatar
Dano you need to remove the 2 compressor line and have new rubber lines fitted, if you look at the rubber to hard line connection one has oil on it this indicates its leaking and the new refrigerant will leak.
Also you may have damaged the reciever drier it should be put in AFTER the lines are flushed and not exposed to outside air, it will absorb the moisture and this will cause the drier to fail
Too bad you didnt follow my post in thread #2, everything i wrote you didnt follow?????
Old 09-12-2009, 03:20 PM
MPDano's Avatar
Sorry bro. I will yank the lines tomorrow and have them redone. I just get on a roll when I actually get 928 time in between a 2 year old and nagging wife.
Old 09-12-2009, 03:36 PM
Petie3rd
Mrmerlin's Avatar
pull out the drier and plug it, let the shop thats filling the system install that part after they flush it, although you may have already damaged the drier.
Dano if you want more info you can call me PM me for my number
Old 09-12-2009, 04:03 PM
MPDano's Avatar
Damn, missed that part about keeping it plugged up. I was wondering why it was under pressure when I removed the fittings from the new one. I guess it's always a learning game.
Old 09-12-2009, 06:09 PM
Petie3rd
Mrmerlin's Avatar
did you pull the headers off of the compressor?? these are the 2 fittings that the hoses connect to.
The reason being that they may not have replaced these O rings there are 2 for each side
Old 09-12-2009, 08:03 PM
MPDano's Avatar
Yup, O-Rings inside were fine and looked new.
Old 09-12-2009, 08:22 PM
Petie3rd
Mrmerlin's Avatar
good Dano, the evaporator also needs cleaning see under where the drier was, the junk in the fins/
Spray some engine gunk in there and rinse it out with a hose plug off the lines so no water gets into the system
Old 09-12-2009, 08:37 PM
MPDano's Avatar
That my absolute thought on those fins. I did brush them off the best I could before putting the Drier on, but didn't want to run cleaner and water with open hoses when the Drier and Compressor was off. Thanks for all this advice as I really needed this.
Old 09-13-2009, 07:37 AM
MPDano's Avatar
Where is the Expansion Valve located?
Old 09-15-2009, 10:10 AM
