How to test fuel pressure on 1986?
I dont see any normal size shrader valves anywhere to hook up the gauge?? Thanks in advanceNel
Old 10-07-2009, 01:08 PM
Petie3rd
Mrmerlin's Avatar
to test the fuel pressure the connection is on the front of the passenger side fuel rail,
when you loosen the cap nut make sure to have a towel under the cap.
There should be gas coming out and there is also a ball thats is used to seal the rail dont let it fall out of the cap it will roll away unless the towel catches it
Old 10-07-2009, 06:27 PM
Thank You. I will get some figures tomorrow. Thanks again NEl
Old 10-07-2009, 06:36 PM
Add a Fuel Pressure Gauge to the passenger fuel rail - $45.
www.************
Old 10-08-2009, 05:39 AM
