Fuel pump question
Will the fuel pump from an 1986 928S work properly if its installed into a 1980 928S euro? I thought maybe they possibly were the same pump, but maybe not.
1980 928S Euro
1983 928S
1988 928 S4
1989 944NA
Old 10-16-2009, 07:37 PM
MPDano's Avatar
Use a proper one for your CIS. It has the longer neck. You may also have a 2nd one at the inlet of the tank (in-tank).
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 10-16-2009, 08:30 PM
EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
so if and when i need to change my pump, iam going to need to change two?.........great.................
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 10-17-2009, 10:30 AM
SharkHead
JhwShark's Avatar
It's not that hard to replace either or both...remember they have gas in them when you take them down...
Be careful when working with parts (petrol/gasoline) and battery or volt generator around.
Have you tried checking then cleaning your's -- take them off and put 12v to them then reverse where you put your two leads. Is the pump spining or not in both directions? If you have a jar of petrol then put hoses from pump to jar when testing cleaning.
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 10-17-2009, 10:53 AM
The in tank pump (if equipped) should be the same for most years BUT the external pump needs higher pressure for the CIS injection system in your 928.
Dennis
Old 10-17-2009, 11:35 AM
MPDano's Avatar
Also FYI, I only changed the external pump on my CIS. I just gutted my internal one since it was not working. My car runs fine although on quick right or left hand turns, it does lean out a little.
Don't drive like your in the Grand Prix and you will be fine.
Old 10-17-2009, 03:54 PM
