-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   injetor change help ? (http://forums.pelicanparts.com/porsche-928-technical-forum/507198-injetor-change-help.html)
hitman3 10-26-2009 03:06 PM
hi i have a 928 1978 euro model after cleaning the injectors i notice that one injector is licking i heard that Mercedes benz injectors (the are 1" shorter than the porsche injectors)are OK to use in my car pelican part number 000-078-56-23-M14 is any one try this before or any advice were to get a cheaper injectors (csi type)
EIPtuningR32 10-26-2009 03:33 PM
edits: **clicking** **(CIS type)**
whats your price range?
EIPtuningR32 10-26-2009 03:35 PM
i would recommend the standard injectors, but if you are looking for alternatives, i remember hearing something about the injectors from Mercedes are interchangeable, but i would wait for a more definite answer from someone else
Barbapapa 10-26-2009 04:17 PM
Those MB injectors work nicely, I 've used them and the car had a crisp, clean throttle with no downsides. Don't worry about the length difference.
A well tuned CIS is a treat to drive!
http://forums.pelicanparts.com/suppo...s/beerchug.gif
MPDano 10-26-2009 05:16 PM
Russ can also give you working advice on these MB Injectors as he runs them on his Euro too.
The thing is, you will be need to replace all 8 if your gonna go with the MB ones. At least that is what I would do. I also had a single bad injector and just replaced that one (stock injector) since I didn't have the funds to replace all of them at one time.
I believe I paid around $35 for the single injector.
MPDano 10-26-2009 05:17 PM
Part # 0437502012 Bosch
Also, keep in mind, you will probably strip the piece (Retaining Ring?) that holds that injector to the Spider Pipe. You will also need the seal for it.
[IMG]http://www.***************/secure/PartImages/0437502012.jpg[/IMG]
hitman3 10-26-2009 11:05 PM
i think i will just do that thank you
rhjames 10-27-2009 07:38 PM
Mercedes Benz CIS injectors p/n 0437502047.
they are brass, and are about 1 inch shorter. supposed to be a better injector than 928 OEM unit.
do not advise replacing just one. CIS injectors can be sonically cleaned, but not rebuilt. if you just replace one, you'll have one cylinder making good power and the rest will be piss poor.....no balance at all.
cost of cleaning is around $15 to $25 each, but you can get the MB units new from ******** Arizona for $21.48 each.
At those costs, you're wasting time and money cleaning----just replace with new.
cheers--
--R
