hitman3
Unhappy injetor change help ?
hi i have a 928 1978 euro model after cleaning the injectors i notice that one injector is licking i heard that Mercedes benz injectors (the are 1" shorter than the porsche injectors)are OK to use in my car pelican part number 000-078-56-23-M14 is any one try this before or any advice were to get a cheaper injectors (csi type)
Old 10-26-2009, 03:06 PM
EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
edits: **clicking** **(CIS type)**
whats your price range?
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 10-26-2009, 03:33 PM
i would recommend the standard injectors, but if you are looking for alternatives, i remember hearing something about the injectors from Mercedes are interchangeable, but i would wait for a more definite answer from someone else
Old 10-26-2009, 03:35 PM
Those MB injectors work nicely, I 've used them and the car had a crisp, clean throttle with no downsides. Don't worry about the length difference.
A well tuned CIS is a treat to drive!
Mike S.
79 928 Racer 427ci 32v 640WHP
Old 10-26-2009, 04:17 PM
MPDano's Avatar
Russ can also give you working advice on these MB Injectors as he runs them on his Euro too.
The thing is, you will be need to replace all 8 if your gonna go with the MB ones. At least that is what I would do. I also had a single bad injector and just replaced that one (stock injector) since I didn't have the funds to replace all of them at one time.
I believe I paid around $35 for the single injector.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 10-26-2009, 05:16 PM
MPDano's Avatar
Part # 0437502012 Bosch
Also, keep in mind, you will probably strip the piece (Retaining Ring?) that holds that injector to the Spider Pipe. You will also need the seal for it.
[IMG]http://www.***************/secure/PartImages/0437502012.jpg[/IMG]
Old 10-26-2009, 05:17 PM
hitman3
i think i will just do that thank you
Old 10-26-2009, 11:05 PM
Heavy Metal Relocator
rhjames's Avatar
Mercedes Benz CIS injectors p/n 0437502047.
they are brass, and are about 1 inch shorter. supposed to be a better injector than 928 OEM unit.
do not advise replacing just one. CIS injectors can be sonically cleaned, but not rebuilt. if you just replace one, you'll have one cylinder making good power and the rest will be piss poor.....no balance at all.
cost of cleaning is around $15 to $25 each, but you can get the MB units new from ******** Arizona for $21.48 each.
At those costs, you're wasting time and money cleaning----just replace with new.
cheers--
--R
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 10-27-2009, 07:38 PM
