gbgastowers's Avatar
Can you flush/clean oil cooler
I have my radiator out of may car which hasn't been run in several years. There is a lot of debris in the oil inlets and outlets. looks like hose bits. Is there a way to flush this out myself or does it have to be done at radiator shop. I thought about blowing air from bottom, or chem tool or oil in reverse flow direction. Gunar- 82 Euro S 5spd
Old 05-11-2010, 07:08 PM
MPDano's Avatar
I would let the pros do it. I believe they can acid wash that bad boy good as new. Take it to a good recommended radiator shop and see what they say.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-11-2010, 09:06 PM
Petie3rd
Mrmerlin's Avatar
I would spray some brake cleaner into the oil cooler and let the tank sit for a while till the debris are loose then rinse out with some engine gunk and water then see how clean things look . If they should acid dip the tank the end tank O rings could be damaged and this could lead to a leaking radiator
Old 05-11-2010, 09:36 PM
Brake clean then water did the trick. It's shiny and clean with high flow. Thanks Merlin
Old 05-15-2010, 01:27 PM
Maleficio's Avatar
Awesome!
I've been wondering about the tranny fluid in the cooler lines and cooler. I want to drain/fill, but I want to get it all out, not just some of it and still have the old fluid from the cooler mixed in.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-15-2010, 01:54 PM
