Network Native
Danglerb's Avatar
CIS, aka Kjet, 101
This is a thread for people to post links, images, etc related to taming CIS injection.
All I know are the basics, and please correct me if I have that wrong as well.
Kjet or CIS, Continuous Injection System is a mostly mechanical pressure controlled system. The injectors have no electrical control, flow depends on manifold vacuum on one side and fuel pressure as controlled by the fuel distributor, WUR, and fuel regulators on the other side.
Fuel pressure regulators adjust the "base" fuel pressure by controlling the amount of fuel from the tank and fuel pump that is returned to the fuel tank. They keep the base pressure a fixed amount above the manifold pressure.
WUR, warm up regulator sends a control pressure to the fuel distributor, and all I understand is that it makes the air fuel mix richer when the motor is cold.
Fuel distributor, combined with the air meter "vane" the flow of air into the motor moves an internal piston up and down and that controls the pressure of the fuel to each of the injectors.
Old 05-17-2009, 11:56 AM
american-kiwi's Avatar
I have a spare fuel Dist' i will pull apart and take some pic's of, for anyone that wants to see how it works
John .........
1978 Porsche 928 5sp LSD
1982 porsche 928 5sp LSD
Old 05-17-2009, 06:46 PM
Network Native
Danglerb's Avatar
Don't just take it apart, rebuild it. very educational.
Old 05-17-2009, 06:55 PM
BB500's Avatar
I just did mine today, and the hardest part was actually spreading the sealant uniformly on the mating surfaces without getting it in the orifices.
Old 05-17-2009, 06:58 PM
EIPtuningR32's Avatar
Send a message via AIM to EIPtuningR32
i know nothing about nothing about nothing. this forum will prove itself very educational to me!
1982 928S euro M28/11
That criminal under the hood is a really bad influence on me: "hey...what about another 1000 rpm? And you know, we're doing 75...but I can go 100 and you'll hear my beautiful voice a lot better! Lets go baby..."
dammit! I'm such a slut~ N! -Normy
Old 05-17-2009, 07:28 PM
MPDano's Avatar
...and what happened when you put it back on the car? Did you get it back to idle?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 05-17-2009, 08:06 PM
BB500's Avatar
Noooooo, didn't you get my v.m. Dano? There has got to be something I am overlooking, I just can't believe this! I don't know why this car is not getting fuel to the injectors!
Old 05-17-2009, 09:47 PM
Network Native
Danglerb's Avatar
Everything works on pressure, you need to measure some.
Old 05-17-2009, 09:52 PM
BB500's Avatar
How do I measure it Mike?
Old 05-17-2009, 09:58 PM
Network Native
Danglerb's Avatar
This one works and is cheap. Whats key is the you need adapters to fit the fuel injection connectors.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97706
Old 05-17-2009, 10:08 PM
rjm65's Avatar
This one has the Bosch CIS adapters?
I'd ask one of the experts at Harbor Freight but you know how that goes.
Old 05-17-2009, 10:37 PM
Network Native
Danglerb's Avatar
Absolutely, before buying verify the Bosch CIS connectors. I bought this one, but it doesn't have the Bosch connectors. OTOH if you need two gauges to trouble shoot some parts of the CIS like Jim Bailey suggested, it might make a good number two gauge.
I would have plenty of rags and maybe a bag of kitty litter to deal with the spills.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92699
I think some like this one from JC Whitney. (image is wrong, review says its cis).
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10101/s-10101/p-100000160266/mediaCode-ZX/appId-100000160266/Pr-p_CATENTRY_ID:100000160266
Old 05-18-2009, 12:11 AM
A proper fuel distributor rebuild would not use sealant. It's really beyond a home garage to do one well.
There is one shop I know of that specializes in CIS and could rebuild a distributor and WUR but I can't think of his name, hmm...he might be in Alabama perhaps?
Mike S.
79 928 Racer 427ci 32v 640WHP
Old 05-18-2009, 06:35 AM
MPDano's Avatar
Actually rjm65 rebuilt his and has been successful, this is where BB500 got his seals. We did recommend him to not use the shellac sealant he purchased, and to use another type of sealant (I am not sure what he "rjm65" used).
We are all from East County here in San Diego, so we're following his progress closely.
Old 05-18-2009, 07:18 AM
BB500's Avatar
The recommended shellac worked great (no leaks) I just let it dry before sandwiching the halfs. Rebuilding the fuel distributor was childs play... I don't think I would recommend someone who doesn't have any sort of mechanical skills to take on the job though, as it can be kind of tricky.
Old 05-18-2009, 08:07 AM
MPDano's Avatar
Cool! I just know that Raymond had issues with the shellac. I saw first hand how his car ran like crap. He used a different type of sealant and it cleared it right up.
BTW, did this clear up the plunger issue (got more pressure?)
Old 05-18-2009, 08:36 AM
devilinblack's Avatar
If you are going to own a CIS car, you need the CIS gauge. The JCWhitney one has been tested and confirmed that it's got everything you need. The Harbor Freight one does not, and while it can be adapted/modified to work, how much time do you have to hunt down connectors and the valve?
Stephen Powers
1978 US 5-Speed
New SoCal928.com Community Site
Old 05-18-2009, 08:48 AM
MPDano's Avatar
Bust out a JC Whitney link
Old 05-18-2009, 08:53 AM
Network Native
Danglerb's Avatar
Stephen did you ever get a chance to compare the JC to the big HF set?
Any chance you could post some picts of the connectors that are needed?
I was thinking about making up some test connectors from some junk yard parts. (not to save $59, but for the science)
Old 05-18-2009, 08:58 AM
Network Native
Danglerb's Avatar
From my post a few messages up.
Old 05-18-2009, 08:59 AM
