Recovering dismantler
neil30076's Avatar
Digital Air/Fuel Ratio Meter hook up
Anyone have practical experience using the Innovate Autosports LM-2 on a 928? Specifically my recently acquired Euro 84 S - it has bungs welded in place on both headers, so should be easy to install the O2 sensor - but i have read about problems getting a good tach signal, they have a frequency pick up and a clamp on, not sure which woudl be best.
LM-2 Wideband O2 Digital Air/fuel Ratio Meter
Cheers
Neil
Neil
2009 Mini Cooper
2004 Mercedes CLK500
2024 Subaru Outback Touring XT
2020 Entegra Coach
Old 12-23-2009, 09:46 AM
Network Native
Danglerb's Avatar
Leo just put a wideband in car.
Old 12-23-2009, 11:40 AM
rjm65's Avatar
Check here Neil for Leo's setup:
Porsche 928 Forums dot com - View topic - Pics of my First 928 and Current Project
I haven't forgotten about the seats, just been kinda busy with the holidays coming up and all. I'll check in with you in a couple weeks to see if they are still available.
Raymond
Old 12-23-2009, 12:32 PM
MPDano's Avatar
Hi Neil, yup I just did the Innovate set up and it's awesome. I know "Exactly" what my A/F is All times. It also helped me troubleshoot a lean condition at high rpms. Calibrating is kind of a pain but well worth it.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 12-23-2009, 01:28 PM
neil30076's Avatar
Hi, Leo - I recall seeing your post, I am looking at the handhled LM-2 unit, which seems to be the same functionaility, but with a RPM channel as well, and was wondering if the frequency sensor ( picks up pulses via the O2 sensor apparently), actually works on a 928, or if the inductive pickup is better ( will work?).
I need to get under the euro anyway and see what i have, i do see separate pipes into what looks like a small cat - may be a X Over- - each pipe has a bung in it for an O2 sensor - but none fitted, then separate pipes all the way back to the muffler and out. There does not appear to be a O2 sensor hooked up, and the BAR tag does not indicate it, and the last CA smog test has O2 sensor marked as N/A -
getting interesting!
Neil
Neil
2009 Mini Cooper
2020 Entegra Coach
Old 12-23-2009, 05:01 PM
Banned
Normy's Avatar
I don't have the Innovate gauge, I have the PLX devices wideband A/F meter, but one of these is something that I recommend EVERYONE install. This one device will allow you to diagnose almost all driveability issues. Probably the best modification I have made to any car.
N!
Old 12-23-2009, 06:08 PM
Network Native
Danglerb's Avatar
I am thinking about tune and swap the narrow band O2 back in. I'd prefer to leave it in and always know my A/F, but what I have been told is that the wideband doesn't last long, less than half a dozen dyno tuning sessions. Depending on the results you both get, maybe I will change my mind.
Old 12-23-2009, 11:36 PM
MPDano's Avatar
I am still not sure what that means as far a longevity. I've had mine in for months without issue. Can you point us in the direction where it may state this?
Old 12-24-2009, 08:14 AM
