Replacement speakers
Say, has anyone replaced the stock speakers? Mine seem to have lost all bass and are from 1986. I would like to replace in same mounting areas with better ones. I have a new JVC radio/DVD installed. I am just looking for better sound not any boom box you can hear 3 blocks away!!!
Doesn't Crutchfield have recommendations? You can always buy elsewhere for pricing. Just make sure you can use your old covers if you have them. My OB doesn't have covers, just holes in the panel.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Yes, I am checking them out for sure. Just wondering what some others have done.
Network Native
Many like the speakers from MB Quart as replacements. Size is a bit of an issue, but nothing like the pain it is for the older cars which require super thin small magnet speakers behind the flat non grille door panels. In hindsight, I would just have the old speakers reconed, and never again use any car stereo installer. speaker repair foam - Google Product Search |
Although my Blau Speakers are still fine for now, if they cease to work, then an Aftermarket is the way I would go. Like these Infinitis for $70 ![]() Crutchfield says it fits.
I installed the JVC myself, did all rewiring and soldering. I am a former test set engineer, been in electronics all my life. Yes, speakers can be reconed for sure but I think there are better, newer designed speakers out now. Crutchfield has some they say will fit.
Alpine SPS-600 Type-S 6-3/4" 2-way car speakers fits in 6-1/2" or 6-3/4" openings at Crutchfield.com for the rear pillers possibly. |
I used those exact alpines listed in harborman's post. I installed them into the factory grills with little modification. essentially what i did was drill 4 small holes through the factory grills to mount the new speaker to it then reinstalled the grills using the factory screws. I had some small button head allens with nuts at hand so that is what I used, though it would have been less obvious if I had used black. I may switch then out for black at a later date, if I ever get caught up with the more critical issues on my list. I'll try to take a couple pics of them installed later today and post them.
Below is a write up I did. Feel free to check it out. I used Diamond Audio D343 and they fit exactly in the factory location no drilling needed!
http://members.rennlist.com/dan87951/928stereoupgrade.html |
Below is a pic of mine Alpines in the factory covers.man the flash makes all the dust dirt and imperfections show up. Anyway, you can see the heads of the allens I used to mount the speakers to the grill before reinstalling the grills in the car. These bould be mounted in the same manor as Dan951 used. also in the install thread Dan linked you can see before installed the ring from the old speaker where the mounting bolts I installed could have been installed instead of using the old speaker ring as he did.
As for the sound; I would say there was a significant improvement, but I do not believe the shape and size of the rear speaker cavities promotes a lot of base. this seemed to be the consensus of many of the posts I read and that if you truely want serious base the real answer it to add a sub. I'm no audiophile so I'm happy with what I've got now.
Ok, I got those installed, just like you did. I did however still use the small rear speakers that were stock along with the newer ones. In order for that to work, I removed the 33 ufD caps (still good) from the old speakers used to cross over to those in the rears and soldered them in place. You need to leave the new caps on the new speakers and put a cap on each speaker in addition feeding those rear ones. If you look at original speakers you will see how the capacitor is wired feeding in series to the one leg of the small midrange/tweeter at the rear. Because of impedence of the new speaker you cannot simply add the small rear ones to the capacitor feeding the new built in tweeter of the Alpines.
My new Alpines (SPS-600) are better since they are two-way as opposed to the original 6" ones, My old speakers were still good however so the increase in sound quality is better but not a drastic improvement. A good CD to test with is "Best of Four play" if you like jazz. It has a good selection of high's and deep bass notes. |
I have those in my 78. They sound great. They fit with a little bit of the bottom of the cover cut away, but they do not look stock in the car. You will not be able to re-use the original covers. I have heard there are some MB Quarts that you can, but I have never seen it.
Tim White '89 S4 A/T, Blue Int Kaschmirbeige '78 5spd, Cork Int - Featured in High Heels & Hot Wheels 2010 calendar!! Petrol Blue '79 EURO 5spd, Black & brown Pasha Int |
EDIT: The originals were mounted behind the vinyl, but the new ones are mounted thru my new vinyl.
Tim White '89 S4 A/T, Blue Int Kaschmirbeige '78 5spd, Cork Int - Featured in High Heels & Hot Wheels 2010 calendar!! Petrol Blue '79 EURO 5spd, Black & brown Pasha Int Last edited by tlsmith1999; 01-29-2010 at 01:02 AM.. Reason: Clarity |
When I did my speaker install I also replaced the door and rear deck speakers at the same time. I installed Infinity Reference 4" 2ways in the doors in the factory locations and a matching set in the rear deck in the factory locations. These are 2way speakers so I did not reconnect the factory tweets in the doors they are now just hole fillers. I am running everything off a Pioneer DEH-P7000bt in-dash. To wire the speakers I ran the rear seat 6-3/4" Alpines (4 ohm) off the rear channel. And the for the 4" Infinities I ran the front and corresponding rear deck speaker in series. The Infinities are 2 ohm speakers and the head unit is designed for a 4-8 ohm load. by running the 4" speakers in series on the front channel it gave a matched 4 ohm load for the front channel and rear. This also allowed me cut all the lows from the 4" speakers with out affecting the channel for the 6-3/4"s.
