funky oil residue in canister
What the heck is this? I found it in the oil canister and on the canister lid (see pics below). I changed the oil about 3-4 months ago and only put MAYBE 300 miles on it. It is a puss-colored, thin, and runny. Smells funky too. (Commence with the wise-cracks now).
1982 928 S Euro 5 speed |
Yeah, mine has that too. It's moisture. Water and Oil mixed. As long as your car doesn't blow white smoke out the tailpipe all the time, then a little bit is probably normal. If it smells like coolant, than that sounds like a leak somewhere (headgasket, oil coolers in radiator, etc).
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Petie3rd
take the car for a 300 mile drive use higher RPMS and then check
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
Smell - It's kinda sweet. I was thinking it might be coolant, but it also kinda smells like fuel, I think. It's a very complicated smell, hard to describe!
Wipe it off, change your oil and drive. If your car doesn't overheat or blow while smoke out the exhaust, then your probably ok. Check it out again after the 300 miles (whenever that may happen).
Petie3rd
with only 300 miles on your oil I would not worry about changing it, the engine needs to see some hi temps for an extended time.
Starting the engine and running it for 10 mins isnt good enough it will just make more condensate Follow the above procedure and then check
Will do.
Petie3rd
since you have about 9 quarts in the crankcase it takes some time for the oil to reach 220 degrees, this is when the water vapors start to evaporate into the crankcase venting
Too bad you don't live right down the street, I think I will be doing the exact same thing on the '79 this weekend.
Tim White '89 S4 A/T, Blue Int Kaschmirbeige '78 5spd, Cork Int - Featured in High Heels & Hot Wheels 2010 calendar!! Petrol Blue '79 EURO 5spd, Black & brown Pasha Int |
1985 944 |
HI! Yes Marvel Mystery OIL can be used in crankcase, gas tank, even auto trans...it quiets valve tappets...removes sludge / carbon build up, cleans fuel lines and injectors..it really works! It was formulated in WWII for the fighter planes in the pacific islands..it was used in the gas and helped the engines deal with hi humidity and high altitude flying....it worked so well..engines lasted twice as long! So it was offered to the public after the war...ingrediants have changed a little but it still does the job well!-J
1985 944 |
