fault code list for s4 928?
hi all, do you know where i could get a list of fault codes for an s4 928, i have just bought the durametric system and would like to find some of the code im getting, cheers tom
Petie3rd
I dont know what your talking about, can you add more info about this durametric system and what problems your having with the car??
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
You need bosch kts 300 scan tool [ the hammer] check my post luftman
hi, check durametric.com. its a great tool for all porsches, it can show all fault codes for any porsche. i have a 89 s4 and the fault code 32 came up but was unkown to the system, i have found out that it is rear knock sensor fault code. cheers
At $347, that's much more obtainable than a hammer. And would pay for itself after 10 trips to my local mechanic.
1991 928 S4 - Horizon Blue |
Petie3rd
my suggestion is to do a complete intake refresh This will usually cure most running problems for many years, also inspect the relays for corroded pins any that are corroded or smell burned should be opened
Suppository of Knowledge
I've used John Speake's diagnostic tool, called the "Spanner". It has internal software that displays the fault codes and interprets them to English. ie: "Knock Sensor 2" would display for the rear sensor fault you describe. It lest you clear/reset the stored coades for the LH (EFI), EZK (ignition), PSD (rear diff controller '90+), ABS and airbag controllers. The firmware talks to other Porsches, and there's a cable adapter available that lets it talks to the '87-'88 928 that have more limited internal fault-storage capabilities. If you have an S4+, this tool is invaluable.
It's possible to swap the rear sensor without removing the intake, if you have small hands. However, if you've never had the intake off, you'll want to pull it and replace the oil vent and vacuum hoses, the knock, TPS and Hall sensors, the throttle switch and the idle air valve all at once. If the car has over 100,000 miles on it, a new or rebuilt MAF is in order also. The knock sensor fault is the first indicator of end-of-life for all of those under-manifold pieces.
dr bob '89 S4 Auto, Black (Needs to be cleaned) SoCal928 Co-Founder |
