rear quarter windows
could anyone please tell me how to get the trim back on the the rear quarters im losing the will to live
1983 928s euro white
Petie3rd
I use some soapy water and a hook wire get one end started and use the hook wire to pull the rubber open a bit as you feed the trim into the channel, the rubber has to catch the trim tab or you have to go back a bit and work in
^^^ Stan ^^^ 2019 BMW K1250 GS 2016 HD RK 1988 S4 Auto , Elfenbein Perlglanz, Pearl Gray 1982 5sp Met black and tan sport seats |
The window rubber holds the trim in so you need to remove the window and rubber and the put the trim on the rubber with the window the put the whole thing back in. Only should take about and hour a side.
The beast 1984 928s twin turbo 5speed LSD/ 508.6RWHP 495RW ft lbs 12.5 psig manifold pressure, MS2 and EDIS-8 nikasil block JE 2618 pistons (TripleT). 2001 AUDI A6 4.2 chip 320 hp. 2002 CHEV Tahoe 4wd. 1971 sonett race car GT4 National Champion now GTL class car sold. The words of a Ford GT man. ( Damit i need to get some turbos) |
first class people as always. just one of these niggly jobs that has to be done,928s seem to have rather a lot
Pro's wrap a piece of string around the window in the seal . Let the tail hang inside the car. Have someone hold the window with the seal installed on it, tightly against the opening it fits in. Go inside the car and you should be able to pull the string and it should roll the seal into the inside of the window opening as it goes around.
Thats probably confusing. I'll see if I can find an explanation online with pics. Heres another explanation: "To install a windshield in a rubber gasket, use heavy string lubricated with dish soap. Place the string at the bottom of the gasket groove and go all the way around the gasket overlapping the string by a foot or so. Place the windshield against the gasket and slowly pull the string straight away from the windshield. This will pull the lip of the gasket over the windshield. After you remove all the string, the window should be in place and no more work is needed." And heres an explanation with pictures: http://www.fordmuscle.com/blog/installing-back-glass/112212
1984 928's w/ 5 speed Smoked Quartz Metalic 1982 928's Turbo w/ 5 Speed Platinum Metalic 1978 Euro Widebody w/ 5 speed Guards Red Last edited by Fabio421; 02-26-2010 at 06:44 PM.. |
Here is what I did and I even have pics of the process:
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
thanks again all excellent info
Remove
Question,
What is the best way to remove the quarter windows? I have a little spot of rust starting on the bottom of the drivers side quarter window. Would like to remove and do a proper repair. |
I have only seen a very few posts that someone could actually remove them with glass and seal intact. I think it's one or the other will have to be destroyed.
i got them out by lifting the inside edge of the seal and slipping in a 2 inch pin to hold the rubber up towards the window put one in every couple of inches and out they come
im sure its on here somewhere
Remove window
Mitsy,
Thanks for the hint! I will be waiting for some better weather her in Chicago before I give it a try. I knew there had to be a way without breaking the glass out. |
your more than welcome thats the first time ive been able to help someone the shoe is usually on the other foot
