S4 brakes an a earlier S conversion??
I can remove any parts needed from an S4 car's brakes for an install on an earlier 'S' 928 and dont know what to pull off...? is i just the calipers, or calipers and rotors, or what?? anyone ever done this swap?? any help or advice mucho appreciated!!
Old 12-01-2008, 11:05 AM
Heavy Metal Relocator
rhjames's Avatar
I did the swap on my 80 Euro.
you should use everything (front end parts) from the S4. They are interchangeable.
on the rear, you will only need a large flat washer to properly space the calipers in relation to the rotors.
I suggest installing stainless braided lines at the same time, as well as a complete fluid flush and replacement.
--Russ
Absence of Evidence, is not Evidence of Absence.
Bill Maher 8/4/09--- "I'll show you Obama's birth certificate, when you show me Sarah Palin's high school diploma."
Old 12-01-2008, 11:20 AM
Fabio421's Avatar
Yeah, what Russ said is correct. If you can pull the entire front S4 suspension it will save you the trouble of sourcing early spindles and using spacers. The rear rotors bolt up but the dust shield will need to be trimmed or removed. The calipers will need to be spaced out a little to fit. Some thin washers work well for this.
1984 928's w/ 5 speed Smoked Quartz Metalic
1982 928's Turbo w/ 5 Speed Platinum Metalic
1978 Euro Widebody w/ 5 speed Guards Red
Old 12-01-2008, 11:51 AM
thanks but can you be a bit more specific when you say front suspension...? yours not talking whole suspension with struts, ect, right? just hub asslys complete,(obviously Im not a mechanic...lol) thanks a ton.
Old 12-02-2008, 06:31 AM
rhjames's Avatar
Yes, the whole assembly.
you need not swap the spring/shocks unless your early car doesn't have the height adjustable shocks--if not, you might install the height adjustables (S4 will have these).
You must swap the A-arms, hubs and spindles at the very least, because the early cars used aluminum ball joints. These can be weak and are not advised for use on any track car. To use the big black (Brembo 4-piston) brakes on an early car, you must do the entire parts swap or purchase the brake caliper adapters (available from the big three suppliers).
It's just easier to do the swap of the entire assembly from a donor S4.
--Russ
Old 12-02-2008, 08:44 AM
lizard928s's Avatar
for the swap you MUST use
Front upper and lower A-arms,
Hub/spindle
rotor, caliper.
I would recommend that you use the S4 shock/spring setup as it has adjustability that the early cars did not have.
On the rears you need a 5mm washer for a spacer to hold the caliper in the correct location other than that everything will just bolt up on the rear.
With regards to a comment about the aluminum ball joints.
If your car has aluminum ball joints, you MUST REPLACE THEM IMMEDIATELY!!!!!
Do not wait to replace them or think they are fine they can be fine one moment and pull apart the next. And do NOT think that they are fine for street driving because they aren't.
Old 12-02-2008, 09:32 AM
MPDano's Avatar
Originally Posted by rhjames View Post
...or purchase the brake caliper adapters (available from the big three suppliers).
--Russ
I looked at the Caliper Adapters on 928 Intl (none on Pelican) and they are expensive ($195) Part # 928 351 999 98
Can they be had cheaper anywhere else? Also, I see you also have to replace the Rotor to a 993 Rotor. Is this it?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 03-25-2010, 11:40 AM
Network Native
Danglerb's Avatar
Whatever happened with the Outlaw brake conversions that Ricer and Brendan were looking at?
Cheap big brake conversion on ebay?
Old 03-25-2010, 01:22 PM
MPDano's Avatar
I was looking at the Porsche 993 Front Rotors and they are expensive. Are other models similar in size and bolt pattern? I was kinda wondering why i need to use specifically 993 rotors with the Adapters. Anyone?
Old 03-26-2010, 02:51 PM
MPDano's Avatar
(crickets chirping)
I guess I' ask again. How come 993 Rotors have to be used when you use the Adapters? How come S4 Rotors can't be used?
Old 03-29-2010, 08:24 PM
