front ride hieght adjustment
Good day friends. I was hoping someone could shed some light on my dilemma. I am attempting to raise the front ride height on my 1984 S. the car has BOGE w/ adjustable spring nut. been turning and turning ( wrench movement from my left to mt right. as stated in a maintenance tips post. for 4 full turns of nut NO change in spring length or movement up wards. NO threads showing either..what gives?..thnx James
1985 944 |
It is possible that the threaded collar that sets on the shock body is rotating with the adjusting nut. if the threads have become corroded and the friction/ adhesion between the nut and the threaded collar is higher than the friction between the collar and shock body the entire adjustment mechanism will spin on the shock and it will not adjust height. you may need to disassemble the unit and free up the threads or replace the nut and or threaded collar to get it to work again.
thats what i was afraid of..i soaked the assembly w/ penetrating oil..this may have made it worse! will adding 2 thick washers under each bolt ( 4 total ) under the bottom shock mount, help raise it a little?
1985 944 |
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
Let's see the actual ride height via pics. I actually put clamps on mine to lower it. Stock front ride height is too high for my tastes.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
I set mine to the lowest spec or I should say to the lower end of the spec. Was it 7 inches? I forget now. If you go too low it throws off the alignment too much. At any rate, once you fiddle with the height, you need a realignment.
i spun that darn nut for an hour with not a mm in movement. Inner workings must be frozen up. Stuck on lowest setting. last weeekend i was bottoming out on an AX track..i needed more hieght...
1985 944 |
Well sorry you are having the problem. Time to remove one and see what is wrong. Yes, too low and your front end hits, bends front pan on RR tracks, etc. You need to raise it up or suffer damage. There is a round spot on the bracket holding suspension in front. That is the measuring point to ground. There is a spec in MM for the height, Maybe 180 MM for front. Hope you did not strip the threads.
You may need to rent a spring compressor and relieve the pressure on the shock and nut. You might have to remove the shock to do this and be careful as that spring will be under a lot of tension. Maybe take it to a shop and have them do it. Hope someone else might have an idea for you.
i read that ride hieght CAN be measured fom bottom of tire to fender well as well..should be 27 inches factory setting..im at 25-1/4 on pass side and 25 on drivers side. looks cool..but. I replaced some sway bar and link bushings (aftermarket urethane) before my race sunday. I think i over torqued the link ends and had a problem with binding..as my ride hieght sank after every run! i fixed that problem...maybe shell be OK now? But i still want to raise the drivers side another 1/4 inch. then both sides another 1/2 inch. my skid pads took a beating on the track..but no real damage thank god!!
1985 944 |
where can you find 'em?? and where would be the best spot to set them? up high? would i run into problems AX racing??
1985 944 |
I think I bought mine at Pep Boys, but i would just call the local Auto places near you before going there.
thnx, i DONT want to take shock out and dismantle! im going to try a few more things to raise another 1/2 inch. as long as the suspension is rebounding now..that was the BIG problem i think...i had overtorqued the linkages and they were binding and not allowing the suspension to rebound properly. Do you know anything about caster effects? for AX / daily driving..would i want more positive or negative?
1985 944 |
I believe more positive caster is goos for straight line speed and track..but negative is good for pivoting hard turns. I do AX with the PCA..region 12. I just finished my first last sunday with the GOLD Coast club. It was the most exciting thing ive ever done..and it was FAST too. track was .7 mile w/ elevation changes..off camber turns...banked turns..hairpins...everything! The club allowed MANY non porsches to enter..saw some good runs..best was a lotus elise..very quiet and FAST..smooth. by my last run i was within 5 seconds of the top drivers! I would suggest bolstering your skid plates under nose! i really beat mine up!
1985 944 |
Cool, i also your running an Auto like me. How did it fair? Did you just manually shift the 1-2-3?
auto worked great... i just left it in lowest setting (2).. w/ first gear starts..my trans has an issue with upshifting into 2 nd too early. BUT with all that torque 2nd worked great! no worries there. i was on street tires..many used slicks..but i think it may have hurt them in the end..very sticky tires / half way thru the event the turns were collecting ALOT of dirt and rubber marbles. That mustve stuck to thier tires and reduced traction..
1985 944 |
Tighten up that Bowden Cable that attaches to your Throttle. That will get you later shifts. I've been messing with mine for months and finally got it where I want it.
