Dim Front Driving Lights?
I noticed from a lot of pictures that the 928 Front Bumper Driving Lights are bright. I always thought they were dim since mine are. Anyone else got dim Driving Lights? How to remedy this?
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior 1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
You could pull one of the plugs and check for voltage.
Are the lenses super-dirty/faded/obscured? |
Good idea about voltage. Problem is that these lenses aren't easily removed.
Here is a little tip if your lens are dirty or if the plastic ones are hazed over. This tip does work because my 99 durango had this problem and I tried it and I was amazed.
squirt a couple dabs of abrasive toothpaste and rub it in with a small buffer, go around and around in circles to make saure you cover the whole area to be cleaned. Wipe it off with a cloth and keep wiping until all residue is gone and then clean it with glass cleaner to remove the haze that will be there after. then stand back and look at the shine.
Chris Ainsworth Elmsdale, Nova Scotia. |
What ever you use, try it on a small area first!
1986 928S 32 valve engine All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires. Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster |
