muffler question
hey guys, I have a question regarding a muffler for the car, I have an 82 928 with single exhaust, I am missing the muffler. I was looking around at the local shops to see what they had, I looked at a cherry bomb muffler with 2.25 inlet and 2.25 outlet, can I install this onto the car or will it be too much back pressure. the next size was 2.5 by 2.5. I was looking at those exhausts because they are the tube design and would go in place pretty good with only a 45 degree. I do have a muffler that came with the car that has a 2.5 inch inlet and dual tip outlet. It would look good on the car but I think it was meant to come straight out of the back of the car and not on an angle. let me know what you guys think, Thnks
Chris Ainsworth
Elmsdale, Nova Scotia.
Old 04-29-2010, 04:46 PM
Petie3rd
Mrmerlin's Avatar
early cars have the outlet coming out at a 45 degree angle
Old 04-29-2010, 05:11 PM
bwmac's Avatar
I would not go smaller then the pipe if i could help it. You also want the muffler to slide on the outside of the pipe. If the muffler or bottle is straight through, as long as the exit is the same size or bigger then the front thats all that matters.
Names Brad, Canada, Fort McMurray.
Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476
Old 04-29-2010, 05:18 PM
MPDano's Avatar
Yes, i believe it's 2-1/2 in and out. 2-1/2 piping all the way.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 04-29-2010, 05:22 PM
I thought for some reason the size of the pipe on the car is 3 inches.
Chris Ainsworth
Old 04-29-2010, 05:30 PM
MPDano's Avatar
Stock is 2-1/2"
Here's what I put on mine:
Porsche 928 Forums dot com - View topic - Pics of my First 928 and Current Project
And a Video for your listening pleasure:
Porsche 928 Forums dot com - View topic - vid of my Moroso Spiral Flow muffler installed
Old 04-29-2010, 05:44 PM
if stock is 2 1/2 then can I go with a 2 1/4 cherry bomb muffler or will that cause back pressure too. the length of the pipe is only 18 inches.
Chris Ainsworth
Old 04-29-2010, 06:02 PM
Network Native
Danglerb's Avatar
I like magnaflow, single chamber is very high flow, kinda loud, dual chamber less loud still pretty high flow. Glass packs, weird mufflers, some loud, some not so loud, none flow like a flowmaster.
Old 04-29-2010, 06:11 PM
MPDano's Avatar
Chris, your homework is to read this post 10 times, then read it again 10 times
Old 04-29-2010, 08:00 PM
I copied Dano's set-up and it sounds gnarly with the bigger Euro engine, which you have (it's a "true" S right?).
1982 928 S Euro 5 speed
Old 05-01-2010, 03:22 PM
MPDano's Avatar
Mines just a normal 4.5 Post up a video and let's hear yours.
Old 05-01-2010, 04:08 PM
I did, months back, on YouTube. It was not that great sounding though because I had not backed the 928 out of the garage. I will have to do it again after I get the WUR calibrated and the timing set- it pops and crackles right now.
Old 05-01-2010, 09:10 PM
