bwmac's Avatar
Originally Posted by Normy View Post
So, HOW does one actually install a capacitor? I'm sure it has to be spliced in some place. Where? What wires actually mount to the thing, and what else is needed?
N
Hey Normy, The 8th post down is a video on how to install a cap.
I agree with Alan in AZ now that you explained it more. I'm a mechanic and I would bet that it is a bad ground. Check the easy one at the right side of the engine, underneath.
For some reason that is the most common problem with this type of electrical issue.
My kid once install 2 batteries in his car to stop the stereo from causing the flux
Hope some of this helps, check out the video
Names Brad, Canada, Fort McMurray.
Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476
Old 05-13-2010, 05:14 PM
928-Electrics Guy
Alan in AZ's Avatar
Originally Posted by bwmac View Post
...I'm a mechanic and I would bet that it is a bad ground. Check the easy one at the right side of the engine, underneath.
Actually in this case if its a ground issue - I'd mostly suspect the console or CE panel grounds since the issue seems pretty localized to the power outlet.
Alan
1994 928 GTS Black/Black Manual
Old 05-13-2010, 07:44 PM
