-   Porsche 928 Technical Forum (http://forums.pelicanparts.com/porsche-928-technical-forum/)
-   -   what is this and what does it do (http://forums.pelicanparts.com/porsche-928-technical-forum/543139-what-what-does-do.html)
trucker677 05-24-2010 03:22 PM
I think part of this is my fault when I said I thought yours was a CIS system, I looked at the pic pretty quick and I thought it was a CIS system, I will say that I do appreciate your help very very much, I do appreciate the help of everyone on this site, I have gained a lot of useful info on this site, between here and talking to HPk7 on the phone trying different things to do to lean it out a bit better.
I found my engine number, here it is M28/16 81C5073. Does it mean my motor is an 1981 model
Landseer 05-24-2010 03:59 PM
Originally Posted by Normy (Post 5368124)
YES I work on these cars. I've owned ONE 928, an '85 with LH-jetronic injection. I've driven it 70k miles in the past 11 years, and 97% of the maintenance was done by me.
I bet it would roast every one of your cars in nearly every contest of speed-
NOW....thank you for your thoughts. Might I ask you to go shove them up your ass? I was TRYING to help another 928 owner, and I think I even retired to the garage in order to access my manuals in order to give this guy some helpfull advice. I'm not an auto mechanic, but I've read these manuals for a decade now, and I've worked on cars since I was four years old when my dad used me to help him change the oil on his cars.
Did I do something wrong? I thought he owned a CIS car. OK....well, maybe not. Your reaction leads me to think that you are a certain body part, the ring-muscle that we use each day to relieve ourselves.
This is ridiculous; Why am I even responding to trash like this? I try to help someone out and I get called names? PSHHT! Go to hell.
N!
The 32V 85 is very different than the 16V non Euro.
I gave input, you countered it with wrong information.
De-wad your panties and drive-on.
Normy 05-24-2010 05:06 PM
Do me a favor and de-wad YOUR panties! I own an '85, but it is NOT a 32 valve. You just stepped on your dick again! You GAVE wrong info the second time! Heh heh! You might want to do some research about 928's-
N!
PS: Anyway....
Landseer 05-24-2010 05:32 PM
Well, its the same engine management system
And, FWIW at this point, I apologize to you Normy for the know-t-all and accusatory tones of my posts. Wasn't necessary and sure doesn't sound appropriate on the re-read. And I sure don't know it all.
Normy 05-24-2010 06:18 PM
Engine management system? What are you talking about? These primitive systems, the LH-Jetronic don't even talk to the the ignition, which is what the '90's vintage systems finally managed!
No need to appologize.
N!
trucker677 05-24-2010 07:03 PM
so, I tried to do some research on my engine. Is there a good website that can show the vacuum diagram for my engine or does anyone have a copy of the vacuum, I listed my engine code earlier in this thread, Thanks
Landseer 05-24-2010 08:27 PM
Best compilation of data seems to be CD's from Moorehouse, via Rog100, that contain reams of other documentation, including & besides full workshop manuals and wiring diagrams and PET parts listings. I'll dig through it and see if I can find it.
Edit: I can't find a master diagram anywhere for 82 specifically. The coverage in the manuals and tech spec books is very disjointed. Check on rennlist, some of the 82 folks may have compiled something or found one.
Generally, you would need to look at the systems for fuel, emissions, timing/distributor and HVAC (all use vac) and dig through the model years looking for sub-diagrams on each and then comparing and contrasting. For instance, you could use 80 fuel diagrams to find that vac layout, then read forward looking for any changes thru 82 that might have affected the vac diagram. Then the same for HVAC. Then study the distributor closely because some have vac advance and retard and its hard to track which is which
Then there is the complexity of the different engine mgmt systems, so these complexities make it impossible for the guy with a single model year interest to jump to the summary for his model year.
Porsche assumed the techs knew what was already on the market, so they just showed updates each year.
trucker677 05-26-2010 03:04 PM
I still havent found anything on the net for a vacuum diagram, it only lists some of them, the ones that I already have done. Does anyone have any other suggestions on where to look. Thanks
MPDano 05-26-2010 03:08 PM
What was wrong with the one I posted for you. It's the only diagram I have ever seen with that piece on your vacuum system.
trucker677 05-26-2010 03:28 PM
there is a couple of differences between mine and yours, I have an advance and retard vacuum hose for my dist.
MPDano 05-26-2010 03:30 PM
I thought you were looking for vac routing for that piece you posted. Of which, neither vac post goes to the Ign Distributor.
JhwShark 05-26-2010 03:37 PM
Chris,
Use Leo's (MPDANO) diagram...
Your car's diagram has the thermo valve in it, with hose coming from a T and before the T the distributor vacuum; the other side goes to the control valve (pas side) with vacuum lines to carbon canister and from the air-box to AAR hose connection. The control valve small fitting where does your hose from this fitting go?? it is usually a red hose.
The valve is listed on 928Intl #058 131 851A. I believe it changes state once warmed up and over a specific temp??
I would believe that this is important for running properly at temp and am unaware (just have not thought through ramifications) of bypassing this circuit.
Jon
curtisr 07-31-2012 06:05 PM
Wow! Who knew that there were so many other 928 owners in little Kingston, Ontario?! Yeah! I have an '82 auto. Ok, Ok, write your own jokes but, the price was right otherwise, yes, I would have chosen a manual tranny...
And as for the other guys, I marvel at your knowledge--you ALL leave me in the dust. Just, please, don't lose sight of why we post. :-)
By the way, I'm in Inverary.
PS: I thought it was a part of a flux capacitor!!!
