hitman3
hhhheeeeeeeeelppppppppppppp!!!!!!
well today i wanted to change my bulbs on the instrument cluster and by mistake i forgot to mark the wiring i have no clue how to connect this 12 wires back the are not color friendly i think some one did a home Job on my wiring if any one have a picture or diagram it will be very helpfully thank in advance my car is a 1979 928 euro
Old 05-30-2010, 08:51 AM
stepson's Avatar
PM John Leidel on Reutterwerk. He's got a '79 and I believe his pod is out of the car.
Old 05-30-2010, 09:42 AM
hitman3
hi dont know how to contact him can you get contact with him and ask him for a picture of his wireing for me
Old 05-30-2010, 09:18 PM
Network Native
Danglerb's Avatar
Wow, none of that is factory, somebody bypassed I imagine a bad connector on the circuit board and soldered all those wires directly to it.
Main concern I think is would stuff fry if you get some wires wrong.
I also don't see how a picture will help since you have no way of knowing if the PO followed original colors with the repair, or if he used the same color on both side of the connectors, or just cut into the factory harness and put on spades.
Do the wire colors on each side of the connection match up?
Old 05-31-2010, 01:32 AM
harborman's Avatar
Too bad he did not at least make a drawing of what he disconnected. Yes, some bad soldering done. Maybe someone has the mating connector with wire colors on it.
1986 928S
32 valve engine
All stock, automatic, 539 Weissgold Metallic, 70K original miles, Hankook Ventus 2 tires.
Previously owned: 67 Vette, 427 L88 Stingray, 74 De Tomaso Pantera L. Latest addition: 2000 BMW Z3 Roadster
Old 05-31-2010, 04:28 AM
Maleficio's Avatar
It kind of looks like the PO used the wiring in the car, just pulled the terminals free from the original car-side connector, cut them, installed male/female terminals, soldered the terminals to the board connector and called it good. I see two pinkish wires conjoined at the terminal car-side, and I also see two pinkish wires conjoined on the pod, that's why I think the colors may match up.
1982 Porsche 928, Auto, 4.5
http://i72.photobucket.com/albums/i166/hethaerto/928Mist2.jpg?t=1305333945
Old 05-31-2010, 07:35 AM
stepson's Avatar
Ok, I PM'ed him. Hopefully he will respond here.
Good Luck.
Old 05-31-2010, 08:07 AM
hitman3
no the colors dont match up any pictures of good connector
Old 05-31-2010, 10:04 AM
SharkHead
JhwShark's Avatar
I believe I read a post on this board, that mentioned (and had a pic) the tabs on the cluster are labeled under the copper strips. If so that might get you started on your tracing by lifting up and looking closely.
Do some searches here first so you find the sample pic's...
Jon
'79 928, 85k Opal Metallic
'99 BMW 540i, 97k Titanium
'72 BMW 3.0 csi, 85k km (euro Deutschland '82) Taiga
Old 05-31-2010, 10:27 AM
hitman3
[QUOTE=JhwShark;5379904]I believe I read a post on this board, that mentioned (and had a pic) the tabs on the cluster are labeled under the copper strips. If so that might get you started on your tracing by lifting up and looking closely.
Jon[/QUO
i cant find them
Old 06-04-2010, 10:54 AM
SharkHead
JhwShark's Avatar
Bummer...
All I can suggest is to look very close at the board contact area for each of the wires; use a magnifier. I do not remember if it is on the side your picture shows or the other side.
Each of the connections for the 12 wires on the board would have had a copper/or other metal strip that the non-existing plug contacts would connect to. Peeling the strip back exposes the name. Do you see any writing where the wires are connected to the board or on the back side of the little tab?
If anyone on the board has a cluster out...please snap a closeup picture for Hitman. Or if you remember the post...post a link, I searched but did not find it either...maybe rennlist?
Thanks,
Jon
Old 06-04-2010, 11:18 AM
MPDano's Avatar
He really needs a pic of the plug (harness) laid flat, so he can see how to match up to the PCB (Printed circuit board). Anyone that has their POD out can take a pic. My Instrument Console is finally all working correctly, so I'm not touching mine if I don't have to.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 06-04-2010, 11:19 AM
MPDano's Avatar
You need something like this but a closer view of both plugs. Which one is the one you need? Looks like you need the plug on the left.
Pic was stolen off Dwaynes website
Old 06-04-2010, 11:28 AM
MPDano's Avatar
Close up of plug on right
Old 06-04-2010, 11:32 AM
Maleficio's Avatar
I posted pics of my connectors over on Rennlist. Mine's an 82 Auto. Not sure if mine's the same as yours.
It took me seven weeks of ownership to build up the nerve.... - Rennlist Discussion Forums
Old 06-04-2010, 11:43 AM
