Main vent switch question
Hi Guys
I have attached 2 pictures with the "main vent switch" that I have. I was wondering how this switch should look like since mine is broken... There are actually 2 and they do work. I was wondering if I can press on both of them or only one at a time? I just dont know what should happen... I can build some small metal device that will enable the plastic lever to press on those switches.. Thanks! http://forums.pelicanparts.com/uploa...1276603304.jpg http://forums.pelicanparts.com/uploa...1276603326.jpg |
I have the same switch in mine and it boggled me for months. I think you can just flip the switch up so the lever catches it. Try it and report back.
I think that there is something missing there so the lever itself cant put pressure on those 2 micro switches...can the both micro switches be pressed in the same time? or only one at a time?
flip the switch up and on the inside of the lever. You'll see what I mean once you do it. Lever will then make contact. Kinda brushes the top of it.
Thanks! I will try to do that!
OK, so it was not possible to lift the switch since it has predefined place and it cant go up towards the lever.
I have disassembled this switch from its place and then I noticed that something was missing since it had small holes for a missing shaft that probably was connected to some metal piece that pressed on the 2 micro switches... I then created a "V" shaped metal strip and using a thin metal pin I have created a shaft and combined them together. I put everything to its place and here is the result: http://forums.pelicanparts.com/uploa...1277041293.jpg http://forums.pelicanparts.com/uploa...1277041321.jpg Now the lever brushes that metal strip and activates the 2 micro switches one by one :D |
| All times are GMT -8. The time now is 05:14 PM. |
