running problems
Hi. I have a 1984 928 with a weird problem. When I try to start the car, it will start and idle for a few seconds then shut off. At other times, I can turn the key and it will run great at all RPM's for a while, then shut off as if I had turned the key off. At other times, it just won't start at all. Any suggestions? Thanks in advance for any replys.
Old 07-29-2010, 06:34 AM
80 928
Possibly your fuel pump, filter, or relay. Are all your grounds solid? Any loose connections?
Can you kill it by wiggling the ignition key?
Old 07-29-2010, 12:03 PM
Thanks for your comments XLR8929. I finally found the problem. It was the injector relay. I had tried the fuel pump relay several times and done the fuel pressure check. Finally, after reading the tech. manual again and looking at the schematic, I found there was a separate injector relay. Thanks again for your help.
Old 08-03-2010, 04:52 AM
