1982 928S
georges 928S's Avatar
no air from middle vents
Hey guys, after replacing the heater valve, no more hot air,air condition is nice and cold, but doesn't blow from middle vents. any ideas. ED.
Old 02-12-2011, 07:34 PM
Griffinroydonal's Avatar
First thing is to check the lines that open the vents and such. They may have a leak or may have come off the fittings
Warning - I play with Porsche's
1970 -914 / 1982 -911
1984 -928 / 1987 -928
Old 02-19-2011, 06:40 PM
Petie3rd
Mrmerlin's Avatar
go to 928gt.com and on page 2 under tips and links find Wallys HVAC system repair
Old 02-19-2011, 09:12 PM
MPDano's Avatar
Yup, Wallys website is a huge help. Are you sure you didn't bump an old vacuum line and cause a leak? If it worked before you did the Heater Valve, then I bet this is what happened.
Buy about 20 feet of 3mm vacuum line and start replacing that old stuff under the hood. I bought the Silicone stuff as it also comes in different colors. I put Blue stuff in the Euro, but stayed Black in the "S."
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 02-20-2011, 05:37 AM
1982 928S
no air from cntr vents
Hi Leo, my center vent quit working before heater valve was changed, and now
iam geeting hot air again. seems i have another problem here further down the
line. please advise. ED.
Old 02-20-2011, 04:57 PM
MPDano's Avatar
Like I said, seems like you broke a vac line somewhere. Try and put some vacuum (with a vacuum tester) to your new heater valve. You should get no more heat in the vents.
Old 02-20-2011, 05:01 PM
same problem here...
turns out i have some leaks in wither actuator diaphragms or lines leading to diaphragms.
go to the page listed or Dwane's garage write ups.. they are great at walking you through the troubleshoot.
Old 02-20-2011, 05:36 PM
MPDano's Avatar
Yup, went through all mine and it ended up being in the Soleniod area under the Center Console. I ended up just blocking all vacuum lines at engine side firewall till I get motivation to tear into that area.
Make sure you run a vacuum line (all time) so you wont get any hot air inside the car.
Old 02-20-2011, 05:45 PM
