Kyle C
Front wheel bearing service
What tool can be used to pull off the dust cover on the front hub to access the wheel bearings? I would like to repack mine but have had no luck removing the cover with the tools I have.
1978 928 5spd hillclimb special
1984 928S 5spd, 1986.5 928S auto
1983 944, 1984 944 track car
1995 Saab 900 S, 1997 Saab 900 Turbo, 1999 Saab 9-3 S
Old 08-21-2010, 11:03 AM
On your ignore list
JE928sx4's Avatar
I use a big pair of tongue and groove joint adjustable pliers, and then rock the cap back and forth till it comes off.
Old 08-21-2010, 11:50 AM
Kyle C
I tried that before with no luck. The cap is stuck in there pretty tight. But if it worked for you, I will try it again if I can't find another way. Would spraying the cover where it fits into the hub with penetrating oil help?
Old 08-21-2010, 12:16 PM
On your ignore list
JE928sx4's Avatar
Spray it first with a little PB Blaster.
Old 08-21-2010, 12:54 PM
bwmac's Avatar
this is what i have always used
Names Brad, Canada, Fort McMurray.
Car is a 1989 928 5L AT from Japan, 17" rims, 95,000 k vin#WPOZZZ92ZKS842476
Old 08-21-2010, 10:17 PM
MPDano's Avatar
I've actually used a small chisel and hammer on mine. Comes off like a charm.
1981 Porsche 928 "Euro" Auto Gunsmoke Metallic Flat - Black Interior
1983 Porsche 928S "US" Auto Light Bronze (Copper) Metallic - Brown Interior **SOLD**
Old 08-21-2010, 11:15 PM
Mad scientist
Peter Bull's Avatar
A hammer and a reasonably sized pin punch works like a charm on my car.
Lean the punch against the the brake rotor and drive the dust boot out by its groove. Give the dust boot a careful beat, turn the hub, say 2/5 of a complete turn, give the boot a beat from the new angle. Repeat until the boot comes off.
Don't beat too hard, that will just damage the dust boot.
/Peter
'84 911 Carrera
'91 928 S4
You can't make a racehorse out of a bull, but you can make an awfully fast bull.
Old 08-22-2010, 01:44 AM
Kyle C
Thanks for the tips, as soon as it stops raining I will give it another shot!
Old 08-22-2010, 06:35 PM
Kyle C
Success! Thanks Peter Bull, I used a socket extension and hammer worked it back and forth until it cam out. Now I have to stop at carquest tomorrow to pick up new hub seals, then I can clean, repack, and adjust the bearings so there will be no more play!
Old 08-27-2010, 02:54 PM
